Fit has terrible brakes?
Old Aug 23, 2010 | 11:30 AM
belfastcowboy's Avatar
Originally Posted by Type 100
That's funny, I actually thought more people would complain about how non-linear the Fit brake pedal is. My GD1 has never had ABS since day 1, and depending on tire compound it can get quite easy to induce a full lockup.
Different strokes I guess. It took me a bit of getting used to but now I have no problems with the pedal modulation - although wheel lockup literally is a misjudged spasm of the foot away. I can definitely say ABS helps a lot, and you guys in the Americas are lucky.
ive driven plenty of cars w/o abs and i like the barebones and down-to-earthness of it all. its fun pumping the brakes on a skid stop
Old Aug 23, 2010 | 04:06 PM
broody's Avatar
Originally Posted by belfastcowboy
thats actually backwards
for repeated applications of the brakes, the system (fluid, pads, rotors) are the issue, not the tires.
all new cars have the braking strength to lock the front wheels. so it could be said that the tires are the always the limiting factor.
i digress from stopping distance (which it has been noted that the fit is not among the best) and make a comment on braking performance and feel. i like the linearity of the brakes. (previously i test drove GTIs which are mega touchy, then quickly grippy w/o any feedback). but i feel like there isnt enough power for immediate-pressure stops. i have the perception that if i needed to make emergency stops, i might hit something.
i try to not put myself in that situation.
That's what I wanted to mean, did a msitake. And if rotors aren't undersized, they won't be an issue. On my Toyota MR2 Turbo I hve good fluid and pads, but cheap rotors, it still works wonders.
And I never felt like the brake pedal has a wrong feeling on the fit. I went to autoslalom yesterday with the car stock, the car did what I wanted without any surprise.
Old Aug 23, 2010 | 04:29 PM
imo the Fit's brakes aren't terrible. what could've help me avoid a crash a few yrs ago was better tires. the shit ziex912's would just not grip well enough and got some abs noise lengthening my braking distance.
if i was on my current Fusion tires (by bridgestone) i could've easily avoided the minor fender bender. so imho get better tires first, then upgrade your brakes.
Old Aug 23, 2010 | 05:30 PM
Krimson_Cardnal's Avatar
Agree. There should be no mistake of the tires role in braking and over-all driving performance in general. The only place the rubber meets the road. The buck stops there.
Old Aug 23, 2010 | 05:55 PM
MNfit's Avatar
my fit brakes fine *shrugs*
lol, I wonder why. I think the stock brakes are just fine for daily driving. I have on times only given the brake pedal light pressure and it feels like it just bites and the car comes to a stop very quickly. When I do up grad my brakes I will probable just get some nice pads and rotors, braided lines and the rear disk conversion.
Old Aug 23, 2010 | 07:34 PM
Type 100's Avatar
Hahaha same here Taken my GD1 to the track quite a few times and I like how honest the brakes are - no ABS. Around this point (after ~2 years driving the car) I had well and truly gotten used to the pedal effort.
Apologies, I thought you were based in the US like most people here and assumed accordingly, but I saw "Belfast" on your location and now stand corrected
Old Aug 24, 2010 | 12:03 AM
i am indeed in the US and my fit does have ABS.
another point re: braking distances. braking distance isnt solely a function of tires (&constants of vehicle weight, suspension, speed)
if you jab at 80mph, it wont immediately skid. the car will slow down first, and then eventually skid (or activate ABS). i like to think of braking as a 2 phase process split by the point where the braking power exceed both the cars momentum and the traction.
before that point, the strength of the brakes plays a big role in slowing the car down. so just because the car can skid on application of the brakes, does not mean its braking performance is hampered solely by the tires
Old Aug 24, 2010 | 11:43 AM
that's a misconception because if you slam on the Fit's brakes with ABS deactivated at highway speeds, the tires will lockup. the weak point is not the brakes, it's the tires. ofcourse suspension will help with the shift in CG, but that's not the case for my car because it is on coilovers and have been tuned many times.
another funny experient done at another forum was a guy buying new BBK for his 370Z. his braking distance lengthened because his new brakes would try to lock up easier than stock confusing the abs system. if the tires (although RE050 is one of the best street tires that come from the factory) grip better for his brakes, obviously the abs would not need to over-react.
so tires first, then brakes.
Grayfox
13
Oct 29, 2012 02:37 PM
johnherreshoff
Apr 13, 2010 10:28 PM
Leo123
Aug 26, 2009 10:31 PM
rjm161
Dec 6, 2007 12:09 AM
Turon
May 30, 2007 03:57 PM
