Honda recalling 1.3 million Fit hatchback for potential headlight loss
Old Nov 1, 2011 | 08:23 PM
solbrothers's Avatar
yeah, the reason for the recall is the burnt wiring. i have no low beam headlights and i blow my right headlight very soon after i replace the bulb. im on my 5th or 6th bulb on that side
Old Nov 1, 2011 | 10:43 PM
timot_one's Avatar
Took it to the dealership today and they're fixing it under the recall. They didn't have the parts, so they're going to get it done tomorrow. From what I hear, they just cut the wire, remove the pin from the connector, and replace it with a new wire and pin with a crimping butt connector. Not exactly the type of repair that I would do myself, since I prefer to solder and heat shrink all electrical connections. The good news is that my buddy told me they guy that does the repair tosses the crimping butt connector and solders the new wire.
Old Nov 2, 2011 | 03:44 PM
cool. yah, usually taps and crimps work fine but never know.
Old Nov 2, 2011 | 10:15 PM
timot_one's Avatar
I never trust wire taps in a vehicle. They actually damage the wire. Over time, the vibration can loosen the connection and create an open. Crimp connectors are only good if you crimp them with the proper crimping tool. If I absolutely must crimp something, I use a ratcheting crimper with the correct die for the terminal I'm crimping. That way you always get the same pressure and a uniform crimp.
For any engine tuck harnesses I make or any modifications I make to a stock wire harness, I always solder all connections and use heat shrink with adhesive. When it comes to that stuff, I don't chance it by taking short cuts.
Ohh yeah. I picked up the car this afternoon. I'll check the repair later this weekend when I have time.
HondaGuy
Jan 16, 2017 08:09 PM
Oniongod
Nov 25, 2015 02:19 PM
Black01
Dec 18, 2010 05:17 PM
SNOWFIT
Greater Calgary Community
Dec 17, 2010 03:44 PM
eglamkowski@angelfire.com
Sep 26, 2005 10:30 AM
