Myth about A/C?
I've heard that the A/C should be run once in a while to make sure the lubricant inside the system is circulated and coating all the internal parts. I rarely ever use the A/C and when I do it's just to 'get it moving' for a bit. Supposedly not using the A/C will cause O rings and other parts to start to leak. I have removed the lead on the defrost mode selector that causes the A/C to engage when in Defrost mode so I could theoretically go a year without using it.
Any thoughts on this?
In defrost mode, you want dry hot air hitting the windshield. In most cases, the way to get dry air is to run the ac. It's not set that way to lube the O rings.
Ditto... I agree with both posts. Don't think it's a myth. Read it in many car columns. I'm not a AC expert. Just makes sense. And just like anything else, less use means more prone to breakage and leaks.
Then again, you're in AK and I'm in CA. The AC working is a bit higher on my list than you...
The issue you can find is that your use of the defrost mode is seasonal; you won't use it all summer and fall, so its not used for 6 months at a time.
OK...that is what I was wondering, so to be safe guess I will run the AC sometimes in the warmer months. Just have to remember to do it. The summers here are mild enough that I generally prefer to just have the windows down. Thanks malraux!
Spent some time in the Bremerton area.
Back on thread. You should be fine using your defrost. The same AC system is being used when you're in defrost mode.
Seattle Rain Festival
Jan 1-Dec 31
LOL
BTW I bought my car at the Bremerton dealership even though I live in Seattle!
Sounds like I'll just turn on the A/C once in a while. In the winter it won't even engage for months because it's too cold out. I do use defrost mode in the winter but not with any need to dry the air. If that should happen I can still hit the button.
Thanks, everyone!
Thanks, everyone!
Vash
Aug 11, 2016 07:56 AM
wskwong
Nov 30, 2012 07:55 AM
