BASE vs SPORT, why does base come with DBW and sport doesnt?
Fit sport and base
handling
LOL ,yeah ,dead thread,hey Subie, increased tire pressures on the left side by 3 pounds to compensate for gas and driver(200lbs) weight.Think I noticed an improvement in handling.JJ
Really? So you're running @ 35 psi?
36 when warm? Would that then be just under recommended pressure of 33 once it cools off? Cause if I recall from previous Googling, tires gain about 4 to 6 PSI when they warm up.
On top of that's I don't see how you are reasoning extra PSI for any side/corner... the springs are pretty going to soak it up. But whatever.
Playing with tire pressures
@jjsifo: i don't think different pressure between left and right is a good thing? unless you're the diligent type to always compensate the pressure whenever you got passengers. lol... i never tried running with different pressure left and right.. only front and back. gotta try it once and see whether it has any effect..
tire pressures
thanks, JJ
Like K said, I have to admit I haven't done that variation either JJ. I've done the front/rear variation also. Interesting... Just thinking as you consume gas then the ride changes too...
Hey on another note, when you have your wife onboard, I thought that's what the radio SVC control was for...
Never tried left right variations either. May need to do that. Any recommended changes if I am hauling a few hundred pounds in the back for a 500mi roadtrip (each way)?
I generally run 35 or 36psi on 205/50r16 (or is it 55? Need to double check)
The Verdict
Ok Gents,just came back from a fairly normal drive and whatever's left of my brain and I have decided 3 additional pounds on the left side feels kind of weird, so now I left 1pound (negligible) on the left side extra. Now the setup is 40 on the left 39 on the right which when you think about it almost the same.Now, this is hot Goobers, not warm or cool,so the experiment is over for now.Subie, I have to try the SVC with the wife as a passenger although Like I said before I become very passive when she is on board.Thanks for the input everybody. JJ
Um? .... bleh.
My tires were 38 cold for a time (even 40 for part of my road trip)... now a little bit less since i haven't pumped any air lately. Gonna drop it down a bit more since I found more center wear on all four tires with a touch of outside wear (dang it, do I have to do negative camber to get even wear?).
The original topic is quite gone... perhaps there should be a thread about experiences (preferably) from the same person about equal PSI on all four tires vs differing front/rear vs differing left/right vs a total free-for-all.
