waterless coolant
Old Mar 27, 2013 | 02:10 PM
Triskelion's Avatar
Originally Posted by krunk13
lol what.... Who told you aluminum doesnt corrode? You ever look inside an old honda or BMW (aluminum block) that white stuff is aluminum oxide. Hot water over thousands of cooling and heating cycles will erode ANYTHING. There is literally no material that can stand up to water and time.
Don't even try to educate lil' Stevie- he knows everything already. Just sit back and laugh about the ruination of all of his vehicles that will occur from his own false beliefs.
Old Mar 27, 2013 | 02:21 PM
Doug Just Doug's Avatar
Honda requires that you change your coolant every 3 years.
Where does that come from? Per Honda's owner link site, coolant is MM 5 on the Fit and I don't see a 3-yr. recommendation except for brake fluid.
Old Mar 27, 2013 | 05:33 PM
thefit09's Avatar
It's not a matter of corrosion happening, it's a matter of cost benefit. When you're "right" sometimes it's hard to understand this concept, and I speak from experience. Carry on.
Old Mar 27, 2013 | 06:27 PM
Steve244's Avatar
What part of "as much" or "pitting" did you fail to read? Also Honda is pretty strict about stating to use their coolant to avoid corrosion/lubrication issues.
Originally Posted by page 256 '09 FM
Continued use of any non-
Honda coolant can result in
corrosion, causing the cooling
system to malfunction or fail.
Of course, if you're Jay Leno and can afford anything for your 80 year old cars with no manufacturer's recommendations or proprietary maintenance products, carry on.
Wreck Ignition
Mar 14, 2024 03:24 PM
Mister Coffee
Mar 14, 2024 03:23 PM
spookyneo
Nov 20, 2017 12:05 AM
ishcm
May 3, 2014 05:06 PM
mmdir2002@yahoo.co.uk
May 4, 2005 04:44 PM
