LOW MPG thread
Old Aug 21, 2006 | 09:29 PM
  #41
mjrossman17's Avatar
Originally Posted by Mx6GT89
I wonder why all these people are getting bad MPG? Im sure having the AC on would require a little more pedal to get through traffic. But still, My Mx6 gets better MPG with the AC on. And my whole fuel system is upgraded.
I think its because most of these Fits have under 5000miles. I know that the car is already broken in and everything but the cars at my job (Carmax Dodge/Chrysler/Jeep) mention best mileage after 10,000miles.
Even though the car may be technically broken in before then, I have always noticed that the more miles on a car (if its running properly), the better mpg. Even MUCH better than EPA estimates.
Old Aug 22, 2006 | 12:14 PM
  #42
nexus4400's Avatar
Fit AT Sport
About 27XX miles on the clock; 34 psi all around.
Best Gas MPG: 40 mpg highway averaging 75 mph without AC on.
Worst Gas MPG: 24 mpg pure street driving with AC on 90% of the time.
Average Gas MPG: 26 mpg 90% city driving with AC on 90% of the time.
I average about 35 mpg driving on the highway with the AC on.
Old Aug 22, 2006 | 03:22 PM
  #43
Fray Adjacent's Avatar
Senior Member
A couple things to consider regarding this situation...
Often times very efficient cars are VERY sensitive to how they are driven.
Couple this with the possibility of either a problem with the AT, OR that the ATs might take much longer to break in, and we get lower than expected gas mileage.
If I had an AT Fit and were getting lower than expected economy, I think I would order compatible transmission fluid and have the fluid changed. Perchance the factory is using the wrong ATF?
This is a mystery that will continue to be encountered and investigated. Keep this thread going! Keep the data coming!
Old Aug 22, 2006 | 03:49 PM
  #44
wyy183's Avatar
I'm getting close to 6,000 miles on my Sport AT. Overall mileage is at 29.5 mpg, with a best tank of 33 mpg.
I have an appointment with my dealer tomorrow to do an ECU reset and idle-learn procedure, which probably wasn't done at PDI.
95% of the time I "baby" my Fit the way that I drive it.
Old Aug 22, 2006 | 06:31 PM
  #45
roenyc's Avatar
just hit empty, gas tank thing lit up at some of my worst miliage yet!!
188.7!!!! on 9.5 gallons. drove a lot of highway this week too. around the 20 mark yet again. and they tell me its the gas. i love this car otherwise! think i am going to check out the BBB and the lemon law.
been looking at others to trade it in but the way it handles i dont want to. i notice that the tych hits the 4000 mark between gears 1 and 2 and 3 (i have an automatic) that seems awful high.
i am at a loss. honda is not taking it seriously. if gas isnt leaking on the ground and the computer cant find it - nothing is wrong.
i am going to use shell gas this week. just for the lady at honda america
Old Aug 22, 2006 | 06:40 PM
  #46
trowpa's Avatar
4000 rpm to shift? Mine shifts at about 2900. Could it be that the computer controlling the AT is needs a flash update?
Old Aug 22, 2006 | 07:12 PM
  #47
Jimmy101's Avatar
Thumbs down
Just went through another tank of gas in my sport a/t.
I topped it off. Drove it until I hit E adn the light came on.
I got 188 miles. Mostly freeway driving with the a/c on.
No passengers. I have 2000 miles on the fit.
Old Aug 22, 2006 | 07:28 PM
  #48
Packy's Avatar
Frequent FitFreak Poster
That isn't right at all. Are you fairly light on the pedal? If I just accellerate at a reasonable rate in my AT, it shifts between 2800 and 3100 for first through third depending on the incline and if I'm by myself or have another passenger. If I slam my foot down, it'll go up to 6k, and if I'm pressed half way down it'll shift around 4-4.5k.
Man, you and Jimmy101 have some bad numbers.
The main normal MPG factors I can think of are:
1) Driving over 70mph (drag is BAD)
2) AC use
3) windows open at high speed
4) accellerating too fast (probably the biggest culprit)
5) lots of stop and go driving
6) low tire pressure
I have a feeling you're both trying to limit the above factors, so your numbers are pretty damn low. Good luck
  #49
roenyc's Avatar
are you concerned about this? have you called honda? are you using cheap gas? not that i really think that should matter unless it has water in it.
Old Aug 22, 2006 | 08:30 PM
  #50
msg's Avatar
msg
hi guys, from the Philippines. i got a 1.5 vtec cvt and i usually drive it in the city with stop and go traffic. i use 16 inch tires with 195/50 bridgestones with 32 psi all. daily drive with ac on cuz its hot in here. average 9 km/li or 22 miles / gal. i dunno if its the traffic here or what. when i used to have the stock tires which are 185/55/15 is used to get the same milage. i wonder if somethings wrong with it or its just the damn traffic.
btw hiway driving is awesome. highest was 48 miles/gallon hehehe
Old Aug 22, 2006 | 11:39 PM
  #51
firstshadow's Avatar
Senior Member
are you guys going over 3000 rpm alot before 3000 miles? and what vendor and type of gas are you using? ie. chevron regular
Old Aug 23, 2006 | 12:49 PM
  #52
Fudgie's Avatar
Something is definitely not right. I typically hit 188 miles near the halfway point on the gauge, especially if I'm driving mostly highway. I have a Sport A/T with around 2200 miles on it.
Old Aug 23, 2006 | 12:54 PM
  #53
trowpa's Avatar
yep around 170-190 for half a tank - on 100% highway i'm over 200 for the halftank mark. This is for a Sport AT w/ 3k miles. You sure you're parking brake isn't on? LOL
(edited cause I can't spell)
Old Aug 23, 2006 | 12:55 PM
  #54
crimsona's Avatar
yeesh
I hit 188 km at the halfway mark... which is a lot less.
Old Aug 23, 2006 | 01:12 PM
  #55
DragonEye's Avatar
I know for a fact that many honda motors work better after about 20-30K on them... heck even better later on. so just wait it out and see how it does after a few thousand.
Old Aug 23, 2006 | 07:51 PM
  #56
Jimmy101's Avatar
I use cheveron & union 76 gas. THe dealer says its the summer formula gas, sold here in Las Vegas. But I still think its to low. I plan on taking it in when I have some free time and let you guys know what they say.
Old Aug 24, 2006 | 08:19 AM
  #57
yo_fitty's Avatar
The info that I have found on ethanol blends show 5% mpg drop on 10% ethanol gas. That would be like going from 33mpg to 31mpg. All blends need to meet the same fuel spec whether it is summer/winter blending for performance or an EPA reformulation requirement. i.e. the EPA used to require oxygenate blends (MTBE, Ethanol...) during the peak ozone season, typically June to September.
Experimenting with different brands/sources could show some good results, though I doubt you would see anything like 10-20 percent changes. To keep it scientific you should run several tanks from the same source, and compare to several tanks from another soure before making any judgements on its impact on your mpg. You want to eliminate as much of the "driving conditions" variable as you can.
Old Aug 24, 2006 | 11:34 AM
  #58
DewaltDakota's Avatar
Sport A/T shifts that high sound like you're putting the tranny in "S"port mode, instead of "D"rive...
Old Aug 24, 2006 | 11:51 AM
  #59
roenyc's Avatar
i started using shell gasoline cause it has more detergent and the honda lady said i should use a better gas then costco. i am at the 1/4 tank mark and am doing just as bad as using the costco gas. just spent more per gallon. 54 miles at 1/4 tank.
Old Aug 24, 2006 | 11:54 AM
  #60
4dr4life!'s Avatar
Try Mobil gas next fill up, I get best results using there gas.
