need obd0 help - 91 crx
Old May 4, 2005 | 11:16 AM
jim beam
Guest
Posts: n/a
anyone have experience with a code 8 condition?
my crx is flashing this and will not clear. it has a brand new
distributor & drives just fine. the check engine light is not on.
code 8 is supposed to be for tdc/crank sensor, but are there any other
conditions known to cause this? [for instance, code 16 is injectors,
but is usually caused by the main relay]
thanks!
TeGGer®
Guest
Posts: n/a
Re: need obd0 help - 91 crx
jim beam <nospam@example.net> wrote in
news:1109225376.49a3cf732da26c8c268b02f1b7dca5fc@t eranews:
Any symptoms other than the ECU flashing the code?
Try clearing the code and see if it comes back again (pull backup or
backup/hazard fuse for 30 seconds).
It is?
TeGGeR®
www.tegger.com/hondafaq/
jim beam
Guest
Posts: n/a
ah! had been pulling the wrong fuse! problem gone. thanks tegger.
> It is?
that's been my experience. 4 different civics.
TeGGer®
Guest
Posts: n/a
news:1109305734.feb44c08e700cb27805bd59970b4a147@t eranews:
>> It is?
Well, Main Relay term 3 feeds power to the injectors, but that feed is
taken before the relays themselves. I guess it must be cracked solder that
causes the ECU to see a no-voltage situation at the injector pins and thus
set a code 16.
TeGGeR®
jim beam
Guest
Posts: n/a
>>>It is?
> set a code 16.
agreed. i'll bet 90% of all throttle body/injector sales have been as a
result of code 16 replacements. the helm manual is utterly useless in
diagnosis of this fault because it assumes the main relay's functioning
correctly and sends you in a flow-charted wild goose chase that costs
serious money. the only point at which it /does/ mention the main relay
in the flow chart, in the '89 helm at any rate, it assumes it's a
cabling fault, not a relay fault.
TeGGer®
Guest
Posts: n/a
news:1109307996.167df128e0fd699c71e100bdd60552d6@t eranews:
>> is taken before the relays themselves. I guess it must be cracked
>> solder that causes the ECU to see a no-voltage situation at the
>> injector pins and thus set a code 16.
> a result of code 16 replacements. the helm manual is utterly useless
> in diagnosis of this fault because it assumes the main relay's
> functioning correctly and sends you in a flow-charted wild goose chase
> that costs serious money. the only point at which it /does/ mention
> the main relay in the flow chart, in the '89 helm at any rate, it
> assumes it's a cabling fault, not a relay fault.
A question then: What would be the symptoms, if any? Stumbling? Stalling?
Just the Check Engine light and nothing else?
TeGGeR®
jim beam
Guest
Posts: n/a
if the motor starts, there's no symptoms. if it doesn't, it lights the
check engine signal & stores code 16. i've never had a motor cut out or
stumble with main relay problems once the motor's running.
John Ings
Guest
Posts: n/a
On Fri, 25 Feb 2005 16:56:12 -0800, jim beam <nospam@example.net>
I have! Sumbitch left me by the side of the road near Wapela
Saskatchewan. Just quit cold after coming all the way from Calgary.
Had I known then what I know now!
FITDragon
Nov 11, 2021 09:08 PM
drkatherine1
Mar 27, 2017 09:52 PM
markielowski
Jan 2, 2011 03:08 PM
madvibes
Aug 31, 2010 07:16 PM
madvibes
Aug 31, 2010 03:51 PM
