93 prelude main relay problem
Old Jun 22, 2005 | 01:43 PM
cocococo1
Guest
Posts: n/a
I have a 93 vtec prelude no fuel and engine check light stays on. is the
light staying on because engine will not start or is the main relay
dead.Any ideas very welcome
Jafir Elkurd
Guest
Posts: n/a
Re: 93 prelude main relay problem
You could have a bad fuse for the fuel pump. On my 89 Legend when the fuel
pump fuse went bad, the check engine light would stay on... (and you
couldn't crank the car, on that one.) A bad main relay can cause all kinds
of problem though, because it powers not only the fuel pump but also the
computer.
"cocococo1" <mtubbies@btinternet.com> wrote in message
news:f0bd5f99b8bf7f989b45ae5a548d10a7@localhost.ta lkaboutautos.com...
TeGGeR®
Guest
Posts: n/a
news:f0bd5f99b8bf7f989b45ae5a548d10a7@localhost.ta lkaboutautos.com:
First thing you need to do is recover that error code. Check out the PDF
referenced here:
http://www.tegger.com/hondafaq/faq.html#retrieve
An error 16 is normally associated with a bad Main Relay.
http://www.tegger.com/hondafaq/mainr...mainrelay.html
Main Relays don't get "dead", they just get cracked solder.
http://www.tegger.com/hondafaq/faq.html#stalling
TeGGeR®
TeGGeR®
Guest
Posts: n/a
referenced here:
TeGGeR®
polvofro
Mar 28, 2017 01:57 AM
bayneman
Oct 11, 2005 10:35 AM
saltydad58
Aug 28, 2005 09:30 AM
Spoilaz via CarKB.com
Aug 9, 2005 10:30 PM
TeGGer®
May 4, 2005 11:16 AM
