How do I pass brake light inspection?
Guest
Posts: n/a
Our 89 Accord had a minor collision which a headlight will not flip
down or up automatically. I have to manually flip them by hand. A
brake and light inspection is due next month that requires a proper
aim from the lights. I seriously can't fix this problem on time. How
do I pass California's brake and light inspection when an inspector
has to manually flip the headlight up and down?
Thanks
Thanks
Guest
Posts: n/a
Re: How do I pass brake light inspection?
> Thanks
Flip the lights up and disconnect the motors, then aim them properly so
they're up and aimed all the time.
nate
replace "fly" with "com" to reply.
http://home.comcast.net/~njnagel
> Thanks
nate
Guest
Posts: n/a
"Sam Nickaby" <Sam@none.com> wrote in message
news:v%%Ie.3030$fJ1.2663@newssvr13.news.prodigy.co m...
He doesn't have to flip them down. Pull the fuse for the motors.
Guest
Posts: n/a
> Thanks
Sarcasm follows:
Sam, are you telling us that it's THE LAW (in California) to point the
headlights the right direction ? ? ? ?
Here in Alberta, Canada, anything goes. One pointing at Jupiter, the
other pointing at JAPAN is the most common combination. :-)
The manufacturers tried to make headlights FOOLPROOF, but forgot that
you can't make it make it illegal to sell SCREWDRIVERS to FOOLS.
Stay safe.
'Curly'
> Thanks
Sarcasm follows:
Stay safe.
'Curly'
Guest
Posts: n/a
in SoCal, there is no brake and light inspection... where are you?
> Thanks
> Thanks
Guest
Posts: n/a
In article <BcydnZUS-L8LLmnfRVn-qA@rogers.com>,
stevebigelowXXX@rogers.com says...
Didn't the '89 have a headlight defeat switch on the center console
behind the hand brake?
--Gene
--Gene
Guest
Posts: n/a
>> Thanks
> Sarcasm follows:
Can't speak for CA, but that is the case in NJ. Badly aimed headlights
are a common reason for failing state inspection, although I have
certainly seen plenty of vehicles on the road with the "one pointing at
Jupiter, the other pointing at JAPAN" combo. We sometimes refer to them
locally as star & worm finders.
>> Thanks
> Sarcasm follows:
Guest
Posts: n/a
NoCal. If the colluision repair cost more or near the value of your car
then a brake and light inspection is due. The car's worth $509US.
Guest
Posts: n/a
are you sure? how does dmv determine the value of the vehicle? sounds
more like a salvage vehicle issue to me because the only time i've ever
had to get a brake & light inspection is when i've re-registered a
de-registered vehicle. in that case, just open the phone book - the
places that do it are listed among the smog test stations.
Guest
Posts: n/a
Probably some agency deregistered my car since I had to report any >$500
accident to the DMV which they asked for the value of the car on my last
title transfer.
title transfer.
Guest
Posts: n/a
or request an extension of time to fix the thing.
news:6OfJe.359$911.124@newssvr21.news.prodigy.com. ..
> "jim beam" wrote
car
> title transfer.
> "jim beam" wrote
car
> title transfer.
Guest
Posts: n/a
In article <v%%Ie.3030$fJ1.2663@newssvr13.news.prodigy.com> , Sam@none.com
says...
Easy. Flip the lights up. Make sure they are aimed properly in the up
postion. Don't flip the lights down. Leave them up all the time until you
can properly fix the lights.
Alex
says...
Alex
chinkyy
Mar 4, 2013 10:37 AM
Doug McCrary
Jul 31, 2005 06:45 PM
brake, break, california, car, easy, inspection, lamp, light, make, pass, repair, requirements, salvage, tail, test
