K20 swap estimated swap costs!
Old Feb 12, 2009 | 10:03 AM
redrumm's Avatar
awesome man good luck
Old Feb 12, 2009 | 11:45 AM
Edison Carasio's Avatar
Thanks! I was reading up on the D series, but I'm leaning more torwards a B. K seems more difficult, and a B might be easier to source or cheaper. I think the B will offer me more options should I decide to get deeper than a naturally aspirated 180 or so HP. Although maybe I could find a D just to drop in and drive the car until I have everything for the B swap. The guy has the engine and trans, along with another set of wheels (haven't seen them yet), another hood and bumper (ran into the garage!), and a header and new exhaust. The engine is just taken apart right now.
Old Feb 12, 2009 | 02:58 PM
90crxfreak's Avatar
sweet!!!! i love my rex.... i'm sure it will grow on you very fast..... any and all info on crx's could be found here... www.cr-xcentral.com my sn on there is the same as here
Old Feb 12, 2009 | 05:08 PM
Registered!
Old Feb 12, 2009 | 08:00 PM
redrumm's Avatar
cheapest b series is the LS which came in the 90-93 integras
Old Feb 13, 2009 | 09:40 AM
So I got to peek at the title the other day, and it's an Si. Now I'm REALLY trying to get him to trade/sell it to me. :) I've decided that I'll probably try to source a B16A from Ebay if it all works out.
Old Feb 13, 2009 | 10:56 AM
redrumm's Avatar
Hmotorsonline.com
just pick on up from there
Old Feb 13, 2009 | 12:17 PM
You guys are all full of win. This forum makes life easier and easier. :)
Old Feb 15, 2009 | 02:30 PM
90crxfreak's Avatar
Originally Posted by redrumm
Hmotorsonline.com
thats where i got my d15b...
I have done research on the b16's and your best bet is and look for the XSi coplete chance over... your best bang for the buck ::Thumbsup::
Old Feb 15, 2009 | 08:39 PM
redrumm's Avatar
or just look for a EF9 or EF8 complete B swap.
Old Feb 16, 2009 | 12:57 PM
Is this the one?
Item 30002
B16A 88-91 (SiR I) Complete Change Over
Price: $ 1599.00 Plus shipping and handling.
Availability: In Stock
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Isn't this the one that came in the JDM CRX? If so, that should just bolt right in, correct?
Old Feb 16, 2009 | 03:09 PM
  #32
redrumm's Avatar
THATS IT
also
PASSWORDJDM HAS THERE B20 MOTORS ON SALE….
Old Feb 16, 2009 | 03:36 PM
  #33
redrumm's Avatar
Old Feb 17, 2009 | 12:31 PM
  #34
If I source all parts and provide them, any ideas on how much labor generally is for dropping an engine in?
Old Feb 17, 2009 | 03:10 PM
  #35
redrumm's Avatar
really depends on where you go. id say $800 or around there since they are taking out your old motor and putting in the new one.
what motor is in your car right now? d16a6? i have that in my hatch and i like it even though its not a B series. it gets up and goes for sure
Old Feb 17, 2009 | 03:12 PM
  #36
Right now the car doens't have a motor or trans. So maybe a shorter job, which means less labor? But $1000 was what I was thinking on the high end.
Old Feb 17, 2009 | 03:15 PM
  #37
redrumm's Avatar
yeah it will be about that much but if it is already out then you should try and do it yourself. easiest part is putting it in.
this motor will drop right in your car
88-92 SOHC ZC longblock
Price: $ 450.00 Plus shipping and handling.
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- 5 Speed ZC Transmission(Add $150)
- Motors
Old Feb 17, 2009 | 03:21 PM
  #38
Thanks for all your help Redrumm. +1 rep for you, more if I could.
Old Feb 17, 2009 | 03:26 PM
  #39
redrumm's Avatar
thanks man. just trying to help. i was in this situation a few years ago when i was trying to find a motor for my hatch. i bought mine from a friend for 200 with tranny and its been running good ever since.
that would honestly be the cheapest solution. to take that D series motor and drop it in your car cause you could use the stock mounts and all the plugs without changing over. The good thing about the ZC tranny is the short gears. With that 120 HP on your crx, since its so light, will be a fun little car.
ive ran Base model RSX, 05 civic SI and a 91 integra with intake, header and exhaust and beat/kept up with them on a stock d16a6.
Old Feb 17, 2009 | 03:31 PM
  #40
redrumm's Avatar
get on D-series.org
nothing but info on D swaps and if you have questions a lot of those people will help you
