Best tips for maintaining car engine
Old Mar 12, 2010 | 03:44 AM
saranya's Avatar
Here are the best tips for maintaining car engine:
1. Engine oil is the most element of a car engine that plays a vital role in car performance. It should be changed periodically or after every 3,000 to 6,000 miles. Also check the oil level and refill the tank if the level is low.
2. Check the condition of the air filter. If you find any kind of dirt or crack in the air filter, immediately replace it or else it would hamper the functioning of the car engine.
3. Whenever you decide to replace engine parts, ensure that you use original components. Faulty and fake engine components may damage the engine completely if they don't fit in well or are not reliable.
4. Use clean fuel for your car. Adding a fuel stabilizer to the engine can also be helpful for preventing gas from going stale.
5. Inspect the condition of the spark plug and if required change them. Damaged or ineffective spark plugs hamper the performance of the car engine and also prevents costly engine repairs.
6. If in case you find any kind of strange noises from the engine, get it checked from the mechanic and make sure that the necessary repair is done.
Old Mar 13, 2010 | 03:20 PM
john21031's Avatar
Don't over-rev it. Don't load it when it's cold. Don't overheat it. Don't forget to change the coolant when it's due (depends on the coolant type).
Old Apr 20, 2010 | 04:05 AM
donaldbradley's Avatar
Great tips. Thanks guys!
Old May 7, 2010 | 01:05 PM
miththu's Avatar
I won't say something new stating that regular oil changes is most important factor to keep the engine running. If you do it more often than suggested by manufacturer's schedule, that's even better.
- Avoid overheating the engine
- Changing spark plugs, air filter, timing belt and other items from maintenance schedule may save you from costly repairs.
- Fix any small problem right away before it causes a serious damage.
Old May 7, 2010 | 06:12 PM
shegetstodriveit's Avatar
more like irresponsible and unnecessary
Old May 7, 2010 | 07:49 PM
08fithappy's Avatar
Depends on the type of oil u use as well. I am now using amsoil. Expensive oil but this oil can go for around 10-12k miles with out being changed. I have seen a couple of oil reports stating this. I will also be sending my oil in around 8-9k miles to see how it holds up
phenoyz
Nov 11, 2016 01:34 AM
jazzivtec
Nov 9, 2014 03:53 PM
saranya
Mar 12, 2010 03:36 AM
Spooling
Jul 21, 2009 10:54 PM
Midnightfit
13
Apr 21, 2008 09:46 PM
