B16A /LSD Toda engine in a '89 civic hatch
Old Sep 17, 2016 | 09:34 PM
  #101
Perrenoud Fit's Avatar
Made in Japan
New TPS what a difference this should be a mataneice done every 60k miles.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20160917_212603_a4f58ce2086afc397eb349228ed86933152e71e3.jpg
Old Sep 17, 2016 | 09:47 PM
  #102
B16 tb cleaned inside and out
Today I just had to get to work on the Hot Rod. Pulled the tb cleaned and honed the inside of the bore. Used a brass brush and light oil to clean up the exterior. New hot water line from the t stat to the tb.
Best part no more cel, smooth excelleration, and runs stronger because the ecu knows where the tp is.
Cooling system and front and rear camber kits.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20160917_205006_8ff6be2e7d6acc709035240c48f9bd619a39a91e.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20160917_204853_f0d46ceebdb2b8dd81612afc16137040c2e6a50b.jpg
Old Sep 18, 2016 | 02:51 PM
  #103
Ma d jik ! !
[I]Great cleaner (RED)<br/>High gloss sealer ( Silver )
https://www.amazon.com/gp/aw/d/B009T...cL&ref=plSrch#
https://www.amazon.com/gp/aw/d/B00CZ...jL&ref=plSrch#
This paint job was pretty beat when I bought the car. But the products above are as close to magic as I've ever used.
The clear coat on the hood had bird droppings burnt into the clear. But the cleaner and elbow grease took it out! I've used alot of products over the years and even buffing these spots don't always remove them.
But holy cow this morning I was trying it on the hood and it took 3 bird etchings right out of the finish!
The kit is like 55.00 but has hi ratings ... now you know too!
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20160918_143301_fd4e95c2d1afa1555705bc0362364f26b07f9762.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20160918_143239_9419de480295dc8403a15e11b0a6392641229f9a.jpg
Old Sep 21, 2016 | 06:39 PM
  #104
[I]Just because of the engine ;
Also received the bypass cooling hose so now the cooling system change out has all the pieces parts.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20160921_182206_3a96706a9d7b557aab253fdde666d5fd27e2b3a6.jpg
Old Sep 24, 2016 | 10:14 PM
  #105
Installed the front camber kit last night and today. The balljoint on the ps was toast. Want to change out the shocks to real coil overs in all 4 corners, right now it has the sleeves on red KYB adjustable, and the rear camber kit then an alinment.
Old Sep 24, 2016 | 11:35 PM
  #106
Installed trim on driver's side
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20160924_232447_a0a2832092a33baf433ea13da32f0c6f78960f34.jpg
Old Sep 24, 2016 | 11:40 PM
  #107
Remember
the show Knight Rider?
Well we have a JDM version and its krazy kool.
I know it'll get me a ticket so I'll have to put a switch in line. But for now it's just fun.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-knight_rider_car_jpg_daca09b285811eecfc2401426666583769967376.jpg
Old Sep 24, 2016 | 11:59 PM
  #108
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20160924_235248_c9511be599a9b5bab0ea65421adc3aede66b0d6c.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20160924_235252_714d50be1b6a01c3c07fce7d377773a8e5007062.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20160924_235259_a6ddb29e27212534380e0a380d4841d571809030.jpg
Old Sep 25, 2016 | 07:56 PM
  #109
installed the Knight Rider switch! broke the ground figuring if the terminals on the switch where to get touched by anything it would not matter. works like a charm.
Old Sep 25, 2016 | 08:11 PM
  #110
Old Oct 2, 2016 | 06:30 PM
  #111
Coating the exhaust piping with hi temp aluminum coating? Time will tell?<br/>But it looks good!
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161002_175619_1e3f6dbd89619d689e0f2e2a325795e2721df846.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20161002_175553_6655566c25819399b881e07178542b7efebb327f.jpg
Old Oct 9, 2016 | 08:43 PM
  #112
She made it through Matthew
The storm/ hurricane was much much more than the the weather forecasts said. 23 hours of rain 11 hours of really strong winds. Flooded all over and downed trees. 12" of rain in 1 day.
Rutherford Dr river!
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161009_070234_1cb7f1dfeab330bc42cc383ed879635d4d80fa52.jpg
Old Oct 12, 2016 | 07:48 PM
  #113
Optima marine battery for the stereo and winter storage
Never used fiddty $s :)
This will be great for the stereo amp and winter storage:
Brake rebuild, coilovers, front end alinment. And she'll be ready for next season. Maybe a new set of rims and tirer to go with the drop? He he he.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161012_185212_0032249f30bb57bd9182b2480cd3a073e7e9b2c2.jpg
Old Oct 12, 2016 | 09:52 PM
  #114
Thunder maker
RF P2D2 12 400 RMS 800 PK.
Vented box
OL'S COOL<br/><br/>500wt @ 2ohms.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-_3_2__172852626944f5cb94bfde256ad18cdbdd7b46c0.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-_3_7e03bb7fba3d90f29e37240402f08ac5b6778d75.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20161008_204554_e26ffd72de76d98297304d52a21b542f914c92c1.jpg
Old Oct 12, 2016 | 09:57 PM
  #115
Going to replace the black one thats on it now.<br/>Black? What was he thinking? <br/>Gotta have some kolor!
Started out silver tonight...
No i didn't paint over the sticker, it has masking tape over it. But the river of clear is going to have to dry b4 i can remove it.
Gold flake on a silver beaks bar with yellow metal cast then clear and metal cast again and 3 more coats of clear.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161012_212733_2b8cefbd3620a1e766f66d2fc8ed75fc15214292.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20161012_212907_5bbc2bc0e38ccafd45394563dde45ba7a6d9bd15.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20161012_220233_4630362b292ccdf1a921b43f2c9909c07b8fd009.jpg
Old Oct 14, 2016 | 09:06 PM
  #116
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161013_112327_de34c0ded71ec6702b25a7cb22ba2f3da783b15e.jpg
Old Oct 14, 2016 | 09:16 PM
  #117
Thunder road
Man this company is a fast shipper with
fedex. Read reviews and all where 5 star.
P2 in a vented box
P5002 power up the p2
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161014_194648_4a5cdc9c9e16829e00abc91e7bc348bb07b9b64e.jpg   B16A /LSD Toda engine in a '89 civic hatch-80-20161014_194658_b4a313df682aa9fa501094c224fda6c3f4aec27e.jpg
Old Oct 15, 2016 | 06:13 PM
  #118
Vented vs sealed > Vented wins
The new and improved thump box!
[I]Optima marine battery in box.
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161015_135008_496f08a28b5dfb423938f08977106d13fb3c8bbb.jpg
Old Oct 18, 2016 | 02:18 PM
  #119
Rockford Fosgate is a winner! Vented is different than the sealed boxes I've been using. The air movement is insane that and being 2 feet away from it when it is on. (Big Smile).
Old Oct 22, 2016 | 08:10 PM
  #120
jdm look, lol, naw just hiding the spider cracks! ha ha
Orange tint on corners , lenses are spider cracking. This gave them a new look. Will be doing the signals tomorrow, time permitting.
E Bay is one of the few places that sells the ef hatch corners and they are all used and too expensive. When I ad the 88 they where still being made. 90 - 91 are now but they're drying up too. There's more than one way to reskin a cat!
Attached Thumbnails B16A /LSD Toda engine in a '89 civic hatch-80-20161022_195822_8b502d5d7209472697da51b608514f7a7ba48d42.jpg
