Inside of a/c and defrost switch
Old 07-09-2018, 12:47 PM
doctor J's Avatar
Red arrow points to the night illumination lamp (dark blue); cyan arrow points to the light transmitting prism from on/off lamp (amber)
Arrows are pointing to the night illumination pins (+ and - )
Same pins with the back plate removed,black return springs are visible at mid level (one spring for each white actuator)
Bottom view; night illumination lamps are removed and entire board can be pulled out
Top view; the main contact board can be pulled out as soon as on/off status lamps are removed
Inverted defrost switch actuator (left) with corresponding contacts on contact board;when flat contact spring breaks off the actuator the switch will not work correctly
A/c switch actuation is shown; it has 3 flat contact springs. The push button face cover (saying A/C) needs to be pried off the actuator; the actuator then slides out from the back
DoYouFit?
95
07-28-2015 08:08 PM
SilverEX15
03-01-2015 07:37 PM
hanzo
08-31-2010 09:20 PM
caliban10010
08-28-2010 06:51 AM
SpoonFitGD3
02-15-2007 07:45 PM
Quick Reply: Inside of a/c and defrost switch
