Horn Replacement
Old Oct 22, 2006 | 03:54 AM
simons2k's Avatar
The '04 S2000 horns sound nice and loud. Anyone know if this is a "plug-n-play" item for the Fit? I think I remember seeing 2 wires inside the connector on the S2k horn.
Old Oct 22, 2006 | 06:25 AM
jaoquinz's Avatar
where the hell is the stock horn located??
Old Oct 22, 2006 | 06:38 AM
vividjazz's Avatar
Someone that Posts too much
Hella Twin Horns are popular throughout Asia on the Fit / Jazz. They are reliable unlike a lot of air horns, don't take up a lot of space, sound good and easy to install.
Old Oct 22, 2006 | 11:00 AM
jaoquinz's Avatar
oh cool thanks! I was looking in the engine bay and getting my friend to press on the horn but still didn't have a clue. I'll look for them tomorrow.
Old Oct 22, 2006 | 11:15 AM
gguest's Avatar
If you have deep pockets try hornblasters.com for train air horns.
Old Oct 22, 2006 | 01:20 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Some of you are describing the horn as an import sounding horn...
The Fit sounds like a boat horn. Like a bass boat. It sounds like shat IMO.
It doesnt sound import at all. Id love to put the tC horn on my Fit. Sounds loud and importish.
Old Oct 22, 2006 | 04:02 PM
MINI-Fit's Avatar
A custom horn would be nice-
How to install it-
http://www.tuneshops.org/index~metho...icle_id~28.htm
Here is an example PIAA horn that fits the civic about $46-50.
http://www.eautoworks.com/html/searc...~Cars~Horn.htm
Demand to be noticed while you're driving your ride.
Tough-as-nails, compactly designed car horn can get you the attention you need. No matter if you are trying to avoid an accident or get some attention, this durable all-weather PIAA car horn upgrade can get you the awareness you need, even if you are in a noisy environment.
Get this Honda Civic PIAA car horn and get the attention you need today.
PIAA automotive sport horn for Honda Civic - 400hz/500hz 115db
Get the PIAA high performance automotive horn upgrade / horn replacement. Compact and lightweight design to fit your Civic. High performance car horn rated at 400hz/500hz 115db will surely get you all the attention you ever wanted. The PIAA sports horn can be easily installed on your Honda Civic. These car horns are all-weather shielded for protection from water, snow, dust, and dirt. The PIAA automotive horn system comes complete with one each of the 400hz/500hz 115db horns and installation instructions.
PIAA car horn for Honda Civic Features:
-- Getting attention around you.
-- 2 car horns included 400hz/500hz 115db
-- Powerful 400hz/500hz 115db dual tone.
-- All weather resistant cover.
-- Easy Installation.
-- Super lightweight.
Didn't see one for the FIT. But the two models look like they generically fit many of the Hondas.
Or if this horn is too mundane then try-
http://www.lacosamojada.com/
Maybe try the custom install by Janice but it won't be cheap.
Old Oct 22, 2006 | 04:37 PM
MINI-Fit's Avatar
More ideas!!
Why settle for just a car horn when you can add a PA system!
http://www.cogapa.com/
Don't click on this button-
http://www.cogapa.com/wavs/G6-1.wav
So many choices- some are funny
http://www.cogapa.com/car_horns_songsnsounds.htm
Make you own sounds too.
http://www.cogapa.com/wavs/G4-10.wav
Old Oct 22, 2006 | 05:26 PM
simons2k's Avatar
So the Fit uses two horns?
Old Oct 22, 2006 | 06:06 PM
MINI-Fit's Avatar
Edit: If the FIT has two horns and you add the PIAA horns can you then make it "four" horns or just the two stock ones replaced by two PIAA horns?
The PIAA horn is two horns each of a different pitch so it has a different more generous sound to it. Think of one note played on the piano vs two notes in unison.
They offer 400/500 hz or 500/600 hz dual horns.
If anyone adds a horn that really like- can you post an audio clip????
Old Oct 22, 2006 | 06:17 PM
kgb4187's Avatar
I was about to buy Hella horns, but then I remembered the security system uses the horns when you lock and unlock the car. I go to work at 4am so it wouldnt work for me
Old Oct 22, 2006 | 07:17 PM
  #32
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
Id like to get this horn..
http://www.florawrecker.com/cgi-bin/..._Code=AIRHORNS
but I don't wanna pay that price.. any better ideas?!
Old Oct 22, 2006 | 08:44 PM
  #33
2hot6ft2's Avatar
Originally Posted by fitjunkie
upgrade your fuse for the horn and swap one out for those 18 wheeler horn, you'll clear your way.....
Just a little FYI. Trucks have 2 horns, a city horn (electrical), and a country horn (air). So unless you plan on installing an air compressor you would only get the city horn which is pretty wimpy in most trucks. At least in the ones I've drove.
The OOO GAH HORN is electric and is from way back around the 1920's or 30's I think. Nowadays it's just a novelty horn.
Old Oct 23, 2006 | 12:31 PM
  #34
Devil Doc's Avatar
Where Are The Two Horns Located At? I Know That Theres One On The Right Front Wheres The Other One?
Old Oct 23, 2006 | 02:50 PM
  #35
blue smiler's Avatar
but u have to remove ur bumber to change ta horn.if im not wrong they are on ta right side.
Old Nov 8, 2006 | 12:16 AM
  #36
LiL Wee FIT's Avatar
Yup! The horns are on the passenger side, under the windshield washer tank.
I replaced the stock horn with the Hella Dual Horns "New Generation". It is definitely a good upgrade over stock. The stock horn doesn't do jack! If I'm on the highway, people don't even hear my horn! Now with my Hella dual horns... I can show my prescense
Old Nov 8, 2006 | 01:17 PM
  #37
Devil Doc's Avatar
how did you wired it? i am planning to do the same.
Old Nov 9, 2006 | 12:23 AM
  #38
it was quite simple....
I took off the bumper, unhooked the stock horn and fed new wires for the new horn :P
I guess the hardest part is finding a way to get power from the stock connector.
Old Nov 9, 2006 | 03:00 PM
  #39
Posts in the NUUDE
I found out what the stock horn sounds like. A NEON!!!!
Old Nov 9, 2006 | 03:31 PM
  #40
carlosalicea's Avatar
is true, but tho, I dont like much the stock horn, O have to admit that when some @s--le don't move or something and there are more cars, I hit the horn, and nobody thinks that is my little fit!!!
