Infinity Basslink Sounds Good!
Old Dec 10, 2006 | 11:20 AM
jdlopez's Avatar
Installed this Infinity Basslink to my Fit Sport. It sounds great. No bass junkie here, but I have to say I may not replace stock head unit afterall. I could use some tweeters on the rear doors, though.
Here's some pics of the intall...
Old Dec 10, 2006 | 02:08 PM
MINI-Fit's Avatar
Nice write up with pictures. Much better than the Honda Sub option.
The Infinity BassLink (200Watts/ 10"sub) is a good choice for any small car that needs to:
-Keep on a budget
-Add some deeper bass to a stock stereo system
-Combine the Subwoofer with a built in amp
-Be easy to install yourself or not have to be too costly.
-Can be found at Circuit City or over the internet.
-Conserve space in a small car.
-Has controls to fine tune your sound:
Here is a crutchfield review of the Basslink vs Kenwood's w00x
http://www.crutchfieldadvisor.com/IS...s_reviews.html
Old Dec 10, 2006 | 07:18 PM
nexus4400's Avatar
How are you going to gain access to the spare tire? Would it be possible to fit it under the back seat?
Old Dec 10, 2006 | 11:05 PM
b17gsr's Avatar
Won't fit under the back seat if you use utility mode.
Old Dec 11, 2006 | 06:09 AM
jdlopez's Avatar
The subwoofer weighs less than 10 pounds. I can still access the spare tire, just a little bit of a pain. The sub will not fit under the rear seat, it's a little too big, not to mention you lose the Magic Seat functionality...
Old Dec 11, 2006 | 10:58 AM
nexus4400's Avatar
Is the fat red wire routed to the postive terminal in the engine bay?
Old Dec 11, 2006 | 01:39 PM
jdlopez's Avatar
Yes, the red wire goes direct to the battery.
Old Dec 20, 2006 | 06:11 AM
bigmanbrainy's Avatar
I tell you what. Im to damn greedy to not have a job(im a student). I want it. Ive been reading all about it. Im getting a multimedia center, and an infinity amp and infinity ef components and coaxials installed all at christmass. And now i want that too! Crud.
Old Jan 2, 2007 | 05:17 AM
aznbo187's Avatar
You might also want to try to aim the sub in different direction (to the rear, upwards). Sometimes it provides for a better sound. Clean setup though, I like the simplicity of it!
Old May 6, 2007 | 10:10 AM
jdlopez's Avatar
Follow up to Infinity's Basslink
Just thought I'd follow up on the performance of my 6 month old Basslink. Or I should say "lack of performance." I recently noticed that my Basslink has become weak and almost inaudible. Upon further research, I've found that this is a common defect on these units. I'll be returning my Basslink to Infinity for an exchange. Hopefully the next one will last longer than the 6 months this one lived for.
Old May 6, 2007 | 11:21 AM
manxman's Avatar
The failure of your sub is interesting (meaning that I'm sorry to hear it but curious---). What was the reason for the failure- did the driver wear out or did the amp quit working?
Old May 6, 2007 | 12:36 PM
smeister's Avatar
Sorry to be OT, but I would like know how much better it sounds than my setup with the Kenwood KSC-SW1. Has anyone heard both of them in a Fit?
Old May 6, 2007 | 02:31 PM
jdlopez's Avatar
I suspect it's an amp issue. It just didn't quit, like you'd expect. It just started "losing power" over time. By the time I realized there was a problem I'd have to have the radio cranked past 30 to even hear it at all... I did sound nice when I first installed it. The amp is probably to that great.
As for the KSC-SW1- A friend on mine had one of these in a Nissan Titan. The Infinity blew it away.
Let's see how long the replacement will last. If I can't get more than 6 months performance out of it, I may just squash the idea and go with something else.
-Zach-
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Nov 29, 2015 01:24 AM
milanojazz
Feb 23, 2011 11:09 PM
whoa42
Sep 4, 2009 09:56 PM
Nighthawk_GD3
Oct 6, 2008 11:19 PM
nutz
May 25, 2008 11:36 AM
