Help
Old Sep 21, 2007 | 01:19 AM
t3chn0rav3rb0y's Avatar
Help
So i've been having this issue. I need to know if i run a 16x7 +40 offset with 205/45/16.... WILL I HAVE TIRE RUB!! im planning on lowering the fit with either EIBACH pro lowering springs or T1R lowering springs!.. PLEASE REPLY!!!
Old Sep 21, 2007 | 02:36 AM
JamesBizzle's Avatar
It'll prolly rub a little, you should be straight though.
Old Sep 21, 2007 | 07:43 AM
DynamicFit's Avatar
With this setup you should have a minimal amount of rubbing. Look under the fender and find where it is rubbing and reduce the size of that area (either roll the fenders or remove liner), whatever the cause maybe investigate. If you don't want to do either you can go to a 195/45/16 or a 205/40/16. If you had a higher offset wheel you could probably get away with the same size tire.
Old Sep 21, 2007 | 10:31 AM
thanks guys!!!
Old Sep 21, 2007 | 12:17 PM
JDMchris.com's Avatar
I run THIS
I cant stress enough that it also depends on the brand of tire you use!!!
Old Sep 21, 2007 | 07:11 PM
this is the type of tire im getting Bridgestone Potenza RE-01R
Old Sep 21, 2007 | 07:39 PM
I run THIS
RE01-R is a AWESOME tire... It would be the tire I run on the S2000 if it wasnt $300 a tire! I also wish the life of the tire was a little longer. Should be OK with those tire... minor rubbing.
jamalridesbikes
Feb 14, 2014 02:03 PM
JDM-Taffeta-S
19
Oct 4, 2011 06:15 PM
trancedsailor
Jun 18, 2008 07:16 PM
WhaTisJDM?
Nov 29, 2007 09:29 PM
Luichenwai
Jun 29, 2007 12:37 PM
