Progress Auto Rear Anti-Sway bar! WITH DIY PHOTOS PAGE 5!
Old Nov 19, 2007 | 01:26 PM
  #341
MarkB's Avatar
Just installed mine. Solid product and easy install. I used the loctite on the bolts to be extra sure. Hats off to Progress!
Old Nov 19, 2007 | 04:47 PM
  #342
NewEdgePerf's Avatar
Loctite is always a good idea!!
Tony D
Old Nov 22, 2007 | 01:05 AM
  #343
LiL Wee FIT's Avatar
Just wondering if any of you guys know the specs of the fasteners.
Metric? Standard?
Diameter, thread, pitch... etc
Any help would be greatly appreciated!
Old Nov 22, 2007 | 08:17 AM
  #344
MarkB's Avatar
I think it was mentioned before that it was Metric. Not sure about the pitch.
Old Nov 22, 2007 | 11:01 AM
  #345
manxman's Avatar
Metric? Standard?
M10 X 1.25 X 30FHCS bolts
M10 flat washers
M10 nylock nuts
Old Nov 23, 2007 | 12:37 AM
  #346
TunaDaMan's Avatar
ARG it's all your fault... every single one of you who gave a positive review of the progress sway bar... you caused me to put in an order tonight on the new edge perf site >_< i know i'll be happy, but damn you all for making it sound too damn good to pass up.
Old Nov 23, 2007 | 12:48 AM
  #347
manxman's Avatar
Now, you'll just be pissed at yourself for not doing it sooner-----
Old Nov 23, 2007 | 10:34 AM
  #348
M10 flat washers
M10 nylock nuts
Wow! Thanks for the info!
Old Nov 23, 2007 | 11:54 AM
  #349
TunaDaMan's Avatar
Perhaps, but i did just get my fit a month ago so maybe a month too late ahah
Old Nov 23, 2007 | 12:31 PM
  #350
manxman's Avatar
You're welcome. I always file the paperwork for any modifications. They help a lot if/when the vehicle is resold.
Old Nov 23, 2007 | 12:47 PM
  #351
manxman's Avatar
Actually, your timing is good. Driving the car for a month gives you the ability to see the difference in handling after the sway bar is installed.
Old Nov 23, 2007 | 02:11 PM
  #352
GeorgeC's Avatar
one quick question while i order
you guys know how thick the stock front sway is?
just curious
Old Nov 23, 2007 | 02:33 PM
  #353
cojaro's Avatar
just curious
Front is 21mm.
Old Nov 23, 2007 | 02:46 PM
  #354
cojaro's Avatar
Don't know if anyone has said this already:
Remember: Bigger isn't always better. Getting the most out of sway bars is a balancing act. For our little FWD, the best option would be to get the rear sway and leave the front sway alone. From what I learned, the end with the stiffer bar (or in the bigger picture, the stiffer suspension) will lose traction first when pushed. Obviously, we don't want the front wheels to lose traction. (On the side note, I know that some autocrossers don't even use a front sway if they have a FWD vehicle.)
Old Nov 23, 2007 | 03:28 PM
  #355
Manxman,
Thanks for answering the question on the hardware! TunaDaMan, your order is on the way, Thanks for your order!
Tony D
Old Nov 23, 2007 | 04:37 PM
  #356
TunaDaMan's Avatar
YAY I'm happy, I got the email too, o I cant wait till it comes in >_< est. to arrive on Thursday, cept I'll be at school the whole day, but when Friday rolls around i got the whole day off, score on that, time to have some safe fun until Friday, then it will be time to really have some fun.
Old Nov 24, 2007 | 10:43 AM
  #357
jits14's Avatar
I just installed mine yesterday and all the positive remarks are true. This piece makes a huge difference. I have front and rear strut tower bars, lowering springs, and front fender braces, so I didnt think I would tell to much of a difference once I put it on. It ended up being very noticable. There is a lot of roll going on in the back that you don't notice till its gone!
The back end just seems more planted and solid....I highly recommend it to anyone(hundred times already said)
Old Nov 28, 2007 | 08:10 PM
  #358
TunaDaMan's Avatar
OK so my swaybar came in one day ahead of the estimated Thursday and I was considering installing it tomorrow morning, but I had a few questions concerning the hardware it came with before i proceeded. After checking out the hardware it came with I saw that I got one 10.9 bolt and five 8.8 bolts, 6 flash washers, I assume these are pretty much good to go. As for nuts, it looks like I got 6 regular nuts instead of 6 nylock nuts, and 5 of them seem to go on almost all the way, looks like I need tools to get them on, and 1 which barely gets on the bolt, so I assume it is the wrong thread size. Just wondering if regular nuts would be fine to install the swaybar and if any one else had gotten mismatched hardware as well. i'll have to conact newedge about this, though i might end up going with the panducky install kit. I really wanted to install this tomorrow, but i guess waiting a few days won't bother me that much.
Old Nov 28, 2007 | 10:02 PM
  #359
manxman's Avatar
Wow!
Yours is the very first hardware screw-up that has been posted. If you have the patience, you should call Joey Berry at Progress Tech. In Anaheim, CA. Their 714 a/c phone number is printed on the instruction sheet. Definitely do not just buy hardware store nuts & bolts- they will not be Grade 8 hardened for automotive suspension use. I bought their first bar after the product hit the market, and all of the nuts in my kit were Nylock style. My suggestion is to insist on getting the correct hardware that you paid for. Tony Dimaio at New Edge Performance will probably not have the replacement stuff since he is not the manufacturer.
Sorry that this happened to you, man. Progress will fix their mistake, but it will take a few days to do it.
Old Dec 3, 2007 | 05:40 PM
  #360
SBT's Avatar
SBT
Hey all - this sounds like an awesome, no-brainer product.
Only one question (it's been touched on, but not addressed sufficiently enough to overcome my mechanical inaptitude) - are there any problems or things to watch out for if/when installing this with coilovers?
Thanks!
