Which iridium Spark plugs for 1.3L Honda fit i-DSi
Old 02-05-2011, 03:32 AM
kris bali's Avatar
Hi all,
Need some help.
Just wanted to know which Iridium spark plugs would suit my honda fit 1.3L CVT.
The denso websites does not have the specs for 1.3L, only for 1.5L it has.
Moreover, with some research, my local retailers suggesting denso IK20 but one
suggested denso IK16, anybody know which is best?
Old 02-05-2011, 05:06 AM
Texas Coyote's Avatar
Originally Posted by kris bali
Hi all,
Need some help.
the IK16 is a very hot plug that retains combustion chamber heat and will cause your engine to ping which is damaging. I use IK22s in my car though IK 20s are recommended... the colder heat range of the IK22 allows my ignition timing to advance more igniting the fuel sooner which gives you a little more power and fuel mileage at cruising speed.... The engine control unit will adjust somewhat for the difference and you may even be able to feel a difference in throttle response.
Old 02-12-2011, 01:41 AM
kris bali's Avatar
ok thanks texas coyote! but isn't the ik22 too cold? no side effects?
Old 02-12-2011, 02:27 AM
I have been driving in record cold weather for the last week with no complaints...It might take a couple of extra minutes of driving to initially warm the engine but It shouldn't since the ignition will be advancing a little more igniting the fuel sooner so it will burn off sooner in the power stroke... In the old days before Fuel injection and Engine Control Units that constantly monitor the combustion chamber for the slightest hint of pinging and retard it back a bit to prevent it, we would adjust our carburetors as lean as possible for maximum top end power and then pull the plugs to check for blistering on the insulation around the electrode... If we saw blistering we would install a colder plug... With very lean mixtures and the colder plugs we would sometimes have to close the gap a little to be able to get the plug to ignite.... I have to use the plugs with the more narrow gap because of the supercharger and tune on my car but if your car is naturally aspirated and no tuning has been done to it the wider gar will give you a larger spark and last much longer.
ansys
11-11-2023 11:41 AM
InsaneGenius
10-19-2015 11:05 AM
Luke92115
04-25-2011 09:21 PM
spreadhead
03-11-2011 04:40 PM
1coolride
02-03-2009 10:12 PM
Quick Reply: Which iridium Spark plugs for 1.3L Honda fit i-DSi
