Konig Helium w/GF210 -- Spacer required???
Old Jan 17, 2008 | 06:58 PM
coupdetat's Avatar
I noticed a lot of you guys are running Konig Heliums and I was wondering, is the 40mm offset of the Konigs enough to clear the calipers and avoid rubbing?? It seems awfully small compared to the 55mm offset of the stock Sport rims. Should I get spacers to make them match the stock wheels offset to avoid rubbing and make my ride not look stupid? I'm planning on getting the 15" btw.
Old Jan 17, 2008 | 07:06 PM
JDMchris.com's Avatar
I run THIS
NO SPACERS NO NO NO! 40 offset is fine.
Old Jan 18, 2008 | 08:12 PM
dgff's Avatar
A smaller offset means the wheel centreline is further away from the centre of the car. There will be NO problems with caliper clearance. Adding a spacer will further reduce the offset.
Old Jan 18, 2008 | 08:37 PM
Illusive's Avatar
Spacers would make the offset lower and stick out more...they don't add to the offset.
EMC2
Apr 29, 2024 12:20 PM
mugenfit79
Feb 15, 2010 05:32 PM
drock305
Jan 6, 2010 08:29 AM
sbualuba
Jan 31, 2009 02:04 PM
KnifeEdge_2K1
Dec 26, 2007 11:09 PM
