TIRE questions,sizes, mounting,pressures ANY tire questions
Old Jan 24, 2006 | 03:11 AM
jazzman's Avatar
I have the 1.3 and from the standard tyres now i have 195/50-15.Someone told me that it is better if i put 185/55-14 but with these tyres my car is looking better.With tese tyres the grip is much better than the standard but it is a little slower.Never mind.
Old Jan 24, 2006 | 10:19 AM
kps's Avatar
kps
Honda Fit Forums Moderator
So, is there evidence that the trim levels in North America are calibrated differently? (185/55/R15 is only 0.7mm off 175/65R14 -- completely negligible since a little tread wear makes as much difference.)
If I get a Fit it'll most likely be a base (actually the middle level here in Canada, which I speculate is equivalent to the US base). I'm not likely to change the wheels, at least not until the factory tires have worn out, but I'm curious to know, if I stick on my old snows next winter, how far off they'd actually be. In real life of course I can wait until I have my next car and check it against highway mileposts.
If you have tires of "width / aspect R rim", the rolling radius in mm is
(12.7 × rim) + (width × aspect ÷ 100)
For example, for the stock 175/65R14 the rolling radius is
stock = (12.7 × 14) + (175 × 65 ÷ 100) = 291.5
You would want to keep the rolling radius of any replacement tires within about 8mm of that at worst.
If you have selected a rim size and tire width, the ideal aspect is
(stock - 12.7 × rim) × 100 ÷ width
For example if you want 205mm wide tires on a 16" rim, the ideal aspect is
(291.5 - 12.7 × 16) × 100 ÷ 205 = 43
so you'd get the closest, 205/45R16.
If you want to know how far off a change will put your speedometer, get the rolling radius of the stock tires and the new ones; your actual speed is
speedometer × new ÷ stock
For example, if you're reusing the 155/80R13 from your '77 Civic (rolling radius 289.1mm) and the stock tires are 175/65R14 (rolling radius 291.5mm), when your speedometer reads 100 you are actually doing
100 × 289.1 ÷ 291.5 = 99.1
Old Feb 6, 2006 | 12:57 PM
dougiepants's Avatar
Avid FitFreak Poster
Best Tire Size for GD3
Looking into purchasing tires for the GD3 for the new wheels I just aquired. Goodyear GS D3 195/50/15 or Falken Azenis 195/55/15 or 205/50/15?
Just curious is all since I heard the Falken has lost alittle traction with the new design and the GS D3 is one of the top rating tires even beating the Bridgestone series....
Old Feb 6, 2006 | 04:19 PM
boontina2003's Avatar
195\50\15 are plenty...
Old Feb 7, 2006 | 10:05 AM
thanks for the help
Old Feb 7, 2006 | 08:05 PM
myfit.org's Avatar
the falkens didnt loose traction, they gaind consistancy. the old azenis, once warmed, got TOO warm and were greasy. so it was a GREAT autoX tire. for road course, not so much. the new ones are MUCH more consistant. i ran 1.5 hours on the road course in my DC5 track car running consistant times for majority of the session. PS: ive had both the old and new on the same car, so ive been able to directly compare. just my 2cents.
Old Feb 8, 2006 | 10:35 AM
yeah I loved the old versions for my old EG with ITR w/ ITBs but long ago that was lol
Old Apr 10, 2006 | 10:14 AM
akrams's Avatar
help on tyre pressure
hey, IM running 195/50/R15 tyres, id like to know whats the best tyre pressure to use on them for a farely comfy and economical ride. tks
Old Apr 10, 2006 | 11:11 AM
plus_c's Avatar
Check your owner's manual or the sticker inside your driver door jamb for manufacturer-recommended tire pressures.
Old Apr 11, 2006 | 08:13 AM
vividjazz's Avatar
Someone that Posts too much
34psi all round. Door placard and manual say 32 to 34psi. If you find the ride too hard lower the pressure but remember doing so will reduce fuel economy, increase tyre wear and reduce traction. Always increase pressure when carrying a big load.
Old Apr 13, 2006 | 04:14 AM
cheffyjay's Avatar
The USA spec 16 inch wheel option is:
HFP 16" Alloy Wheels
8-Spoke wheel design. Carbon bronze finish. Comes with HFP logo. Recommended tire size 205/45 R16.
- 16x6 1/2
- 55 Offset
http://www.collegehillshonda.com/hon...ies/wheels.htm
Old Apr 13, 2006 | 04:06 PM
  #32
divisionerror's Avatar
Anyone know the weight of those 16" HFP wheels yet?
Old Apr 13, 2006 | 04:24 PM
  #33
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
Is it worth buying HFP 16" or just sticking with the 15" sport version.
Old Apr 13, 2006 | 05:56 PM
  #34
Iamthespy007's Avatar
I've been wondering that too....I like the rims but I don't know if it won't go with certain colors or not...what's yawl's opinion?
Old Apr 14, 2006 | 06:02 AM
  #35
cheffyjay's Avatar
Hoping for sub 12# wheels
I am hoping that the Kosei K1 TS will somehow work.
http://www.koseijp.co.jp/engfl/n_p5_k1.htm
where are all of the JDM options? Is it just a matter of waiting a few months for more options and info out there?
after hearing some harsh criticisms of ride quality I am wondering if I want to go with anything lower than a '50 series' tire. It will be a daily driver, after all. (I am secretly pleased that you cannot cram big $$ 20" rims on this car. Tires and wheels are going to be a lot cheaper.)
Old Apr 14, 2006 | 11:00 AM
  #36
corey415's Avatar
The HFP 16" are mainly for aesthetics. They may be heavier than the 15" Sport rims. Personally, I would just swap out the stock 15" tires for a more aggressive performance tire, like the Michelin Pilot Exalto PE2. I think having a more aggresive tire is better than having a bigger diamater rim.
If you can afford HFP 16" rims and aggresive tires, then go ahead. But thats not going to be cheap.
Old Apr 14, 2006 | 08:57 PM
  #37
JDM-Bill's Avatar
would 15x6.5 fit?
Old Apr 15, 2006 | 05:33 AM
  #38
cheffyjay's Avatar
Elsewhere in this forum I found this list of 'ideal' wheel sizes for the FiT:
15x7 +42/+38
16x7 +42/+40
17x7 +42/+38
Seeing an ad in Grassroots Motorsports Magazine with some FiTs sporting ROTA rims, I went to their site www.rotausa.com but found it sadly lacking in info and detail. (they had some fine looking rims with 8 and 10 bolt patterns--what are they for?)
Tire Rack dot com is not yet up to speed on the wheel options for the FiT. I have been looking at rims that would fit a late 90s civic (4x100) but I am not sure about offset. Anybody have any thoughts on comparable cars for shopping/daydreaming purposes (keeping the above 'ideal' numbers in mind?
Old Apr 30, 2006 | 03:42 AM
  #39
mightyjazz's Avatar
35psi all round for my 195/50/16 tires
Old Apr 30, 2006 | 08:27 AM
  #40
bschurma's Avatar
The owners manual on mine states to run them at 32 PSI all around. But 35 will probably get you better milage.
