2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
How to remove?
Old Feb 4, 2010 | 03:23 PM
ej96hatch's Avatar
How to remove?
How do you remove the 2 trim pieces on the roof and the base of the antenna? I am thinking about putting some vinyl on the roof and want to install it without these pieces getting in the way!
Thanks
Scott
Old Feb 4, 2010 | 03:48 PM
gimme's Avatar
Master FitFreaker
i am not 100% on your car, but you will go to thre rear of the car and push the rubber trim forward towards the motor. you dont need a lot of force, it will move. And as for the antenna, you'll need to remove the headliner.
Old Feb 4, 2010 | 05:13 PM
ej96hatch's Avatar
I will give that a try this weekend! Thanks!
Old Feb 5, 2010 | 03:50 AM
HONDAMATIC's Avatar
im not sure on the GE but if the roof trim feels like theyre metal, they have retaining clips every foot or so and are very easy to ding. antenna you probably wanna take off your c pillars and sag the headliner a lil bit and it should be a 14mm nut
Old Feb 5, 2010 | 09:51 AM
ej96hatch's Avatar
I will give that a try! Is there any trick to removing the c pillar garnishes?
Thanks
Old Feb 16, 2010 | 03:24 PM
beangrower's Avatar
so how'd it go? I also want to black vinyl my roof eventually and want to remove my antenna.
Old Feb 16, 2010 | 06:50 PM
ej96hatch's Avatar
Haven't done it yet! I'm still researching where to get the vinyl from! I will let you know! I want to do it asap so....
Old Feb 19, 2010 | 02:19 PM
jnesselroad's Avatar
+1 for this. i installed the vinyl without removing this stuff... it came out pretty well, but def would be better if i knew how to take these pieces off. i'm thinkin about redo-ing it, but not until i know this info.
as far as the c-pillars, i've been pulling trim off the GE randomly, and most of it is just snap pieces.
Old Mar 7, 2011 | 03:46 PM
Java^FiT's Avatar
I just received the vinyl I went with and I will be installing it soon on my fit. I will let you know how it goes and how these things are removed. I do not plan on removing the antenna base because i got a shark fin antenna to go over my base, solves that issue! haha. I am also covering the fin with vinyl.
For those that want to know i decided to go with HEXIS Carbon Fiber Vinyl which was designed specifically for auto as in contrast to the paint-harmful 3m di-noc. Plus i think hexis' stuff looks better.
I will post pics when done!
Old Mar 7, 2011 | 06:53 PM
Krimson_Cardnal's Avatar
The roof trim pieces are clipped in at each end. Carefully pry up the molding around 6" behind the front end. That should release the clip - there's a keyhole slot in the clip, pulling the molding slides the clip rear wards to allow the clip to release.
Old Mar 8, 2011 | 11:46 AM
How much was the hexis? And where'd you get it?
Old Mar 8, 2011 | 12:14 PM
Java^FiT's Avatar
it was about 170 with a felt block squeegee including shipping. I got it from hexis
Edit: I bought 3 yards total
Old Mar 8, 2011 | 10:04 PM
DecalDude's Avatar
$170 for 3 yards? shoulda contacted me, i coulda hooked you up =D
Old Mar 8, 2011 | 10:21 PM
Java^FiT's Avatar
did you have the hexis cf vinyl? i compared it to the 3m and i prefer it much more. I diddnt think u had that one?
Old Mar 8, 2011 | 11:15 PM
Java^FiT's Avatar
I thought I would put the real instructions for removing the GE8 roof trim:
Old Mar 8, 2011 | 11:37 PM
Yep, that's it, just like I said, only in the real picture. Good post
Old Mar 10, 2011 | 10:53 AM
DecalDude's Avatar
i dont have it but i was planning on stocking the hexis soon and if someone woulda wanted some i would have gotten it early.
yes the cf vinyl from hexis is much better than 3m dinoc, it is an actual vehicle wrap whereas the di-noc isnt(not a lot of people know it but di-noc is actually an architectural finish vinyl it was never made for auto applications though it seems that has become its biggest sector). not to mention hexis is much much more wallet friendly than the 3m.
but 3m does have another series of vinyl made for vehicle wraps that comes in the cf textured pattern.
i actually have some samples from a dif company that just started making a cf vinyl and i love the look of the pattern and workability of it and might actually start stocking it as a distributor so i will get super good prices on it.
Old Mar 10, 2011 | 01:45 PM
Java^FiT's Avatar
ah ok, well maybe if I need any more of the Hexis I can order it through you.
Old Mar 10, 2011 | 07:53 PM
DecalDude's Avatar
sounds good. i was told they are working on some new vinyl types that should be pretty sweet.
marmaladedad
Aug 21, 2018 05:11 PM
Kdawgz
Nov 13, 2014 06:09 PM
blackvitzrs
Nov 3, 2014 12:04 PM
jrzy2nr
Aug 10, 2008 09:55 PM
yelo
May 23, 2008 05:49 PM
