Fit Pros - Help Me Out With My First Mods
Old Sep 24, 2008 | 11:19 PM
AWDturbo's Avatar
OK, I need some help on a few minor things to start on my first mods:
1) How do you remove the front dome light cover? (so I can access wiring to hardwire a Valentine One radar detector.) I pulled on it with some muscle, but it didn't come off - didn't want to break anything, so I stopped.
2) How do we kill the DRL's? On Subaru's there's a moduel under the dash near the steering column that gets pulled.
3) What are the model codes for the light bulbs in the 2009 Fit (primarily headlight, turn signals, fog lights, dome lights.) A couple sites I usually reference don't have 2009 info yet.
Thanks for any good info/tips you guys have.
Old Sep 24, 2008 | 11:22 PM
SD_MR_FIT's Avatar
dam...the 09s have DRL? thats cool i guess.
i dont know......
i just hard tap the rader to my cig lighter.
Old Sep 25, 2008 | 12:50 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
https://www.fitfreak.net/forums/2nd-...headlight.html
fogs i think are h7 not 100% sure though
Old Sep 25, 2008 | 01:08 AM
EXWRX's Avatar
I was gonna say Progress rear sway bar, but it's an '09. Not sure now.
Old Sep 25, 2008 | 01:16 AM
badself's Avatar
I think I read recently pulling fuse #15 kills the DRL's.
Old Sep 25, 2008 | 03:07 AM
Neebs's Avatar
I am going to assume they're going to utilize the same model numbers from 07-08:
High & low beam headlamp:
9003/HB2
Parking Light Bulb Size:
2827
Front Turn Signal Light Bulb Size:
992 (7440A)
Rear Turn Signal Light Bulb Size:
992 (7440A)
Tail Light Bulb Size:
168 7443
Stop Light Bulb Size:
7443
High Mount Stop Light Bulb Size:
7440
Fog Light Bulb Size:
H11-55W
License Plate Light Bulb Size:
168
Back Up Light Bulb Size:
7440
Front Sidemarker Light Bulb Size:
2827
Rear Side Market Light Bulb Size:
168
Ash Tray Light Bulb Size:
None
Map Light Bulb Size:
None
Dome Light Bulb Size:
DE3175
Trunk/Cargo Area Light Bulb Size:
168
Wouldn't hurt to go ask your dealer.
Old Sep 25, 2008 | 06:19 AM
Whats A Fit?'s Avatar
you are correct!
Old Sep 26, 2008 | 11:01 PM
AWDturbo's Avatar
Update...
Well yesterday (day 2 of ownership) was a busy day, and besides geting the windows tinted, I also:
> Killed the DRL's (thanks for the fuse-pull tips!)
> Replaced the headlamps with Sylvania 9003SU Ultras
> Hardwired the Valentine One, tapping the reading lamp power wire.
In case anyone is wondering, using a small screwdriver you just gently pop out the front reading lamp covers/switches to gain access to the screws holding the lamp assembly in place.
Now I just have to make a stinkin' decision on WHEELS!
Old Sep 26, 2008 | 11:04 PM
manxman's Avatar
'09s have a rear anit-sway bar (Sport models).
jl0r
109
Jan 6, 2019 07:52 AM
Kimomono
Feb 24, 2013 08:47 PM
hkfooey
Aug 13, 2010 09:53 AM
Bigkatdaddy
Oct 14, 2009 01:02 AM
LDO
13
Mar 10, 2008 12:24 AM
