Fast-Forward music on Flash Drive?
Old Dec 11, 2008 | 03:10 AM
tanstaafl.'s Avatar
Post Fast-Forward music on Flash Drive?
My '09 Fit with Navi has the option of playing MP3s on a flash drive through the USB connection. This works better than I thought it might. The only problem I have seen (so far) is that when I try to fast-forward in a song, the play time indicator advances but the music does not. When I release the FF button, the song continues playing right where it was when I started FF.
Do other people have this behavior, or is it just me?
tanstaafl.
Old Dec 11, 2008 | 11:06 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
i'm not sure. mine works perfectly fine.
now i want to check and see if the files on it
are mp3.
will post up later.
Old Dec 11, 2008 | 04:26 PM
raigomaru's Avatar
I don't have the NAV but on my unit the FF works with mp3s (usb interface). Granted it's not the fastest, it skips forward at 3 second increments.
Old Dec 11, 2008 | 06:53 PM
skyghene's Avatar
I have non navi and the fast forward definitely works. Only thing that sucks is the 3 second increments. I was trying to fast forward halfway through a 4 hour radio show on mp3... Eventually I just decided to listen to something else
Old Dec 11, 2008 | 09:44 PM
tanstaafl.'s Avatar
Are you sure it's really fast forwarding? I thought mine was fast forwarding, the play timer was incrementing in 3-second increments, the audio played a tiny hiccup at each 3-second advance, it looked and sounded like it was fast forwarding. But after advancing three minutes, I released the FF button, and even though the play timer said I was 3:30 into the song, the audio was still at the 00:30 where I had been when I started the FF.
It might just be some idiosyncrasy with my particular flash drive. I'll try another one and see if it behaves differently. SWMBO* wants me to put some Christmas music in the car, so that'll be a good way to test it.
tanstaafl.
*SWMBO: She Who Must Be Obeyed
Old Dec 12, 2008 | 12:37 AM
niko3257's Avatar
well i looked at my usb drive and all songs are mp3.
so no i don't have the problem.
Old Dec 13, 2008 | 12:30 AM
CBX's Avatar
CBX
I tried it on the way home tonight, FF and fast back work fine on my non-nav unit.
Files are mp3 ripped in windows media player from CD.
Old Dec 13, 2008 | 08:30 AM
Lek's Avatar
Lek
After reading this thread I decided to try my USB socket for the first time. I plugged in the adaptor and aux found it. So, I put some MP3 format songs on my new 2g flash drive, fixed it to the adaptor and on the screen said unsupported. Hmm, maybe my flash drive is too big. I works fine on my computer.
Cd works fine with the same MP3 music.
Old Dec 13, 2008 | 04:41 PM
reako's Avatar
It wouldn't be that the drive is too big, as I have a 32gb flash drive in mine. You most likely just need to re-format the drive. (*Note - This will erase all data from your drive!) Plug it into your computer, find the drive within "My Computer", RIGHT-click the drive and select "Format". Be sure to select FAT32 for the format type option, and you can just perform a "Quick Format". Try this and let us know...there's more we can try if it doesn't work.
Old Dec 13, 2008 | 08:18 PM
Lek's Avatar
Lek
Thanks reako, that did the job. It works great now just like my CD's.
This is such an easy fix, it should be put on a sticky.
jamis
May 25, 2019 02:34 PM
schwimmair
Dec 30, 2011 12:05 AM
nuoccam
Sep 9, 2011 06:23 PM
lifthard1
Nov 28, 2008 08:41 AM
IfTheFoo
Oct 13, 2008 03:09 PM
