Dashboard Disassembly
Old May 15, 2009 | 01:21 PM
mdomb529's Avatar
Are there freely available instructions (or schematics, or photos) for disassembling my 2009 Fit Sport AT's dashboard? I don't want to risk scratching or breaking anything in the process of installing a second power outlet.
I didn't see anything directly on point in the forums, so I apologize in advance if this has already been covered elsewhere.
Matt
Old May 15, 2009 | 02:31 PM
reako's Avatar
Off-hand I can think of CBS1023 and his epic sound deadening install thread, others may be able to find more for you.
https://www.fitfreak.net/forums/2nd-...tml#post639838
Pretty sure I know what has to be done
Looks like to take the dash out you need to remove these 3 bolts from inside each door jamb..
Then the two in the center..
It should just kinda slide out at that point, of course the steering wheel needs to be removed as well as a bunch of connectors im sure.
Theres a TON of stuff on the drivers side, almost not even worth it, and on the passenger side it looks like I can just pull the HVAC blower out and it should give me quite a bit of room to work with. If I feel I need more I'll prob just yank the whole dash next weekend.
I took a bit of a break today and test fit some panels in the rear, and i'm having BIG fitment problems around the wheel wells, I think i'm gonna have to take a layer off. Hopfully I can pull off the luxuryliner in one piece and then scrape off the overkill and reapply the luxuryliner. I really want to focus on killing noise in the wheel wells becasue it seems to make a dramatic difference. I'll post some pics up later.
And this:
Old May 17, 2009 | 10:47 PM
mdomb529's Avatar
Thanks for the info. Can I assume I don't need to do full dashboard disassembly in order to add in another power outlet?
Old May 18, 2009 | 10:53 AM
mdomb529's Avatar
Perfect. Thanks so much.
cargirl2B
Feb 2, 2009 09:34 PM
jhp7395
Oct 25, 2008 11:35 PM
Mixedwun
Aug 1, 2008 02:49 PM
coupdetat
Mar 24, 2008 07:13 AM
richard612
Feb 10, 2008 04:17 PM
