AM Radio performance
Old May 28, 2006 | 08:28 AM
coloradocraig's Avatar
Haven't seen many references to AM in the forum - guess I'm one of the few remaining listeners. But my preferred companion when driving, especially at night, is the weak distant AM stations. After spending the last 11 years in a car (BMW) with poor AM radio performance, I am DELIGHTED to say that the AM in the Fit is outstanding. Honda made the right decision with the external antenna rather than one of the lousy in the glass antennas. Absolutely no ignition noise and excellent reception of weak stations. Sun glare on the display sometimes bothersome, but all-in-all, I'm one happy camper.
Old May 29, 2006 | 12:22 AM
corey415's Avatar
People listen to AM??
Old May 29, 2006 | 02:05 AM
Packy's Avatar
Frequent FitFreak Poster
Cool, good to know the AM is great! I listen to AM on the way home from work every night.
I thought that AM antennas were always internal loop -type, while FM was always a whip antenna or in-glass antenna?
Old May 29, 2006 | 03:24 AM
aziatiklover's Avatar
Master FitFreaker
wow sorry I never use am so I dont know about it
Old May 29, 2006 | 03:31 AM
sw20's Avatar
I listen to AM on my way to work as well since I like to be aware of any traffic issues to and from work
I do however notice that I get feedback whenever I drive under powerlines. Does anyone else get this? Kinda annoying
Old May 29, 2006 | 08:35 AM
watchful one's Avatar
AM reception is based on an internal ferrit bar antenna, fm uses the external antenna. The fit's radio reception absolutely sucks. My element's was by far superior. I live outside a metro area and can't believe the stations I lost after switching from the element to the fit. Both use the external roof mounted antennas. The BMW radio must have really sucked to consider the fit an upgrade. I also miss the element's subwoofer. For real bass tones and balancing of the equalizer range it was great.
Old May 29, 2006 | 09:13 AM
jake95825's Avatar
Radio reception not too good...
My radio reception isnt too great. I read somewhere here that a few others had the same issue. Something about the antenna not being grounded properly. My AM reception is good. Got to listen to Art Bell .
Old May 29, 2006 | 10:57 AM
Wiggles's Avatar
You can also download Coast To Coast from their website and burn the shows to CD's which will play in the Fit's radio.
Old May 29, 2006 | 03:13 PM
willmax11's Avatar
I told Honda Canada about this problem, I have to hit the off button because it is so loud the spkrs. rattle.
I like the buttons on the stereo and all the other features.
Old May 29, 2006 | 03:31 PM
rayzer59's Avatar
Antenna
The first thing a tech looks at when AM reception is poor is continuity to the external antenna. On many cars, FM will seem to be ok if the antenna lead is loose or disconnected, but AM is a disaster without a good external antenna.
If you have a reception issue, get to the dealership and if they try to say it sounds ok to them, have them compare your vehicle to other like vehicles at the dealership. A problem will be easy to spot.
And post your experience in the Warranty section of the Fit Talk section for others to see.
Old May 22, 2008 | 12:35 PM
jeandeau's Avatar
I have bad reception with my stock radio. The dealer says "no warranty, listen to your CDs." he does a Db sig noise test in the shop, but won't drive around the block to check for a vibration related loose connection problem. Regional rep says talk to your dealer". I will probably install the longer Toyota Matrix antenna and diaassemble the car to check for loose connections or pinched coax cable. I'm not happy.
Old May 22, 2008 | 12:46 PM
FITrunner's Avatar
Haha! I listen to am now and then. Traffic, sports, news, some good stations on there if you dont feel like listening to music. When I had my '67 GT500 I could ONLY listen to AM because that was the stock radio on the thing.
Darkstars
Mar 21, 2016 12:03 PM
kbonus
Nov 10, 2014 04:52 PM
blazej
Aug 22, 2012 10:55 PM
orion42
Jan 23, 2009 08:54 PM
gar1013
Jan 22, 2009 09:44 PM
