How to get better antenna reception?
Old Aug 22, 2012 | 11:45 AM
blazej's Avatar
Hi. My commute takes me between 2 metro areas, so my radio reception is spotty.
Is there anything I can do to improve it? Maybe a longer antenna? If possible, I would like to avoid any wiring into the car's battery.
My setup is all stock, btw.
Would something like this work?
Amico Auto Car Rotatable Antenna Ornament Silver Tone w Hex Wrench Screw : Amazon.com : Automotive
Thanks.
Old Aug 22, 2012 | 12:49 PM
humm... would you be able to change your listening style to listen to mp3's or internet radio? iheartradio, pandora, winamp, etc. i dont even listen to FM/AM radio these days unless in my garage playing top-40 in the background just to keep my head fresh with the times. (i dont fall into the top-40 age group).
if so you can just hook you your celphone headphone output into your Fit and if you have unlimited data, well, it's all free.
Old Aug 22, 2012 | 01:14 PM
blazej's Avatar
I could and do listen to podcasts, MP3s, audio books... I have Pandora, but I like the morning radio shows (in either Metro area). I heart radio would work, but an antenna is ideal.
Could I put a 1' or 2' antenna in place of the factory one?
Old Aug 22, 2012 | 01:16 PM
sooznd's Avatar
some people have installed a sharkfin antenna, I wonder if it improves reception any?
https://www.fitfreak.net/forums/2nd-...n-antenna.html
Old Aug 22, 2012 | 01:59 PM
would a longer antenna damage the roof? especially going through a car wash or something?
ive done PDR repair on a roof of a car where the guy accidentally drove it through the carwash and the rotating brush bent the metal surrounding the antenna...
Old Aug 22, 2012 | 04:58 PM
JoeB's Avatar
Thanks.
Might want to read Product Description first...
Product Description
Made of rigid metal and plastic materials, can effective resistant static electricity.Can be adjusted between 0~90 degrees, its convenient to set while in the three-D parking area.With adjustable length and rotatable design, and wide metal screw type base.Trendy and graceful, car antenna makes your driving more joy!For car decoration purpose - not a genuine antenna.
Old Aug 22, 2012 | 09:14 PM
Dwalbert320's Avatar
I have a Shark Fin. Performance was same as OEM.
The are two things you can do. There is a signal booster or an amplified antenna that you can purchase from Crutchfield.com
The other more expensive route is to invest in a HD radio set up. The antenna is dual band and it really rocks when you listen to regular AM/FM stations. My wife has this in her Pilot.
Old Aug 22, 2012 | 10:49 PM
HD radio is going to suck unless you have very good reception. unlike analog FM, when the signal weakens the sound drops off completely (mutes). if one's having issues receiving analog FM, chances are HD radio is going to SUCK big time.
HD radio works best stationary at home, imho.
Old Aug 22, 2012 | 10:55 PM
That very well could be but my wife as an HD radio set up in the Pilot and it gets reception miles and miles further than my OEM radio in my Fit. By that I mean when the HD antenna is used to pick-up FM reception.
The only time we have issues with the HD radio is mid town and only on certain streets with no view of the sky at all. In the open I can vouch for the HD set-up over stock any day.
Darkstars
Mar 21, 2016 12:03 PM
kbonus
Nov 10, 2014 04:52 PM
granburysprint
Oct 5, 2009 04:47 PM
orion42
Jan 23, 2009 08:54 PM
gar1013
Jan 22, 2009 09:44 PM
