Mileage reports: Automatic transmission (5AT)
Old Jun 1, 2008 | 08:45 PM
  #1041
xorbe's Avatar
Originally Posted by LizardKing
Can you explain what makes the transmission lock/unlock and why that would be good or bad?
Also, if you left it in D, the fuel should have cut off, giving you (effectively) infinite mpg.... Or so I've heard; I won't know for sure until I get a scangauge, which I keep putting off on account of the wife.
Right, it's a game with DFCO. I would never coast for 3 miles in gear in DFCO mode -- I'd slow down too much. Use DFCO when slowing down or stopping is in order. Like use DFCO down a steep hill to maintain speed, instead of coasting in N plus the brakes. DFCO is tricky to use in the a/t, as I have to pull on the paddle shifter to keep the rpms up, as DFCO stops somewhere around 1000-1500 rpms.
Total lock-up means the transmission is in a more efficient mode -- slippage is eliminated. I assume the car tries to lock-up the a/t whenever it can for better mpg, but I'm not sure of all the parameters that control the mechanism.
Putter down the freeway in 5th (paddle mode) at 60 mph. Now floor it, and the rpms will jump as it leaves total lock-up mode. Cruise again, and it will lock back up.
Old Jun 2, 2008 | 11:19 AM
  #1042
LizardKing's Avatar
Honda Fit Forums Moderator
How can you tell when it is locked? Actually, if I'm in 5th going 60 mph and floor it, my RPMs remain relatively unchanged; I have very little acceleration in 5th above 3k RPM. Maybe my lockup thingy is broken?
Does DFCO occur in gears other than 5? If you're going to hit the RPM range where DFCO stops so you downshift to 4 to keep your RPMs up, does DFCO still occur even though your only in 4th? Thanks for the help!
Old Jun 2, 2008 | 12:54 PM
  #1043
HarumaN's Avatar
mpg
With gas prices rising, I've tried to be more conscious of my driving habits this past tank of gas. No jackrabbit starts, kept the rpm's under 3000 the whole time, ran with the windows up and vents on (no AC) when practical. I let my foot off the gas when I see a stop ahead.
Did not use cruise control, and did not put the car into neutral at any time. I had to use the AC a few days as it's starting to get really hot out.
Got a solid 34 mpg city. Very pleased.
Old Jun 2, 2008 | 01:34 PM
  #1044
HaveaFit!'s Avatar
The only real way to tell is to know your car. What he was trying to say is that when you floor it, it should unlock and the rpms go up (same gear). When you left off. . .they should drop. What is happening is that unlock mode is like slip of a clutch to increase power. Thats bad for MPG.
Its only present in Automatic Transmissions.
Old Jun 2, 2008 | 01:38 PM
  #1045
HaveaFit!'s Avatar
Originally Posted by xorbe
Using the scangauge last night, it's better I think to keep the transmission in total lock-up. Better to (sport a/t) put into 4th locked, than to let the motor strain in 5th in slushbox mode (no lock up).
Same principle for small hills, the a/t will leave lock-up mode, so pop it out of cruise control and bleed the speed until the crest.
Coasting down the Altimont in N for 3 minutes at 70 mph @ 270 mpg was fun...
Which is better? a speed such that its always locked up in 4th, or a speed where its always locked in 5th? (faster speed, say 70mph)
Old Jun 4, 2008 | 09:51 AM
  #1046
ghostagent's Avatar
24 MPG with AC on city driving..
Old Jun 4, 2008 | 12:23 PM
  #1047
Tomwaits's Avatar
Ghostagent, keep a record of the mileage and take the car into the dealer. First though, remember to drive smoothly, no rapid starts or stops and try to drive as efficiently as possible (hard to do in city driving, I know). Driving style helps a lot. 24 mpg in the city seems low though. I've never seen anything below 29 in the city, even with the air on.
Good luck.
Old Jun 4, 2008 | 01:06 PM
  #1048
henryd1981's Avatar
It it is a new Fit getting 24 mpg, I can see that. I know it takes time for a new Fit AT to get better gas mileage. I'm now in the upper 20s.
Old Jun 4, 2008 | 01:54 PM
  #1049
xorbe's Avatar
Man, stoplights are brutal according to the scangauge. I mean, it's obvious of couse, but it hurts to watch it in real time! Cue the Chevy ad tune... "Like a rock!" Also, the first few minutes are low mpg for whatever reason, cold engine.
Old Jun 4, 2008 | 11:56 PM
  #1050
LizardKing's Avatar
25 mpg with ac off for me
Old Jun 5, 2008 | 12:49 AM
  #1051
NaTuReB0Y's Avatar
last tank ---------
290 miles with 9.56 gallons = 30.3 miles/gallon
Old Jun 5, 2008 | 02:49 AM
  #1052
Rob22315's Avatar
My last tank - 33 mpg (283/8.53) with mixed driving and little AC. I've got 3K miles on the car. I've increased tire inflation to 42 psi, use DFCO as much as possible, and accelerate slowly from a stop. DFCO FTW!!
This mpg figure is based on my actual odo reading may be low as my odo is now off by 6-8% due to a change from steelies to alloys based on GPS calibration. I need to do a more thorough calibration to really see how much my readings have changed. If I'm right, this may be 36 mpg or more!!
Old Jun 5, 2008 | 08:29 AM
  #1053
HaveaFit!'s Avatar
What size tires and rims? How much do your rims weigh?
Old Jun 5, 2008 | 10:01 AM
  #1054
Rob22315's Avatar
I replaced my steelies with OEM sport alloys so I'm running the same wheels/tires as many Sport owners. My base doesn't have the skirts and spoiler though.
Old Jun 5, 2008 | 08:06 PM
  #1055
kusojiji's Avatar
That's strange. I would've thought OEM optional stuff would have been the same OD.
Old Jun 6, 2008 | 02:35 AM
  #1056
Rob22315's Avatar
Per the math, the difference between the steelies and the alloys is about 2%. The steelies are 14", the alloys are 15" rims. I measured the difference at around 6-8% with my GPS. The odo may have been off to begin with or tire circumference may not be an exact science. I can't say which but I can say I was surprised the difference was much larger than the math said it should.
Either way, 33 with the AT is still pretty darn good.
Old Jun 13, 2008 | 11:40 PM
  #1057
magicseat's Avatar
sport auto; not even broken in yet @ 245 miles on the clock! 245/8.09 gallons = 30.28 MPG! (with a 1/4 tank left) i love it! driving between 65-80mph freeway and some street.
Old Jun 14, 2008 | 12:20 AM
  #1058
airborne200208's Avatar
Finally averaging 30 mpg per tank. almost 9000 on the odo.
Old Jun 14, 2008 | 03:25 AM
  #1059
xorbe's Avatar
Traffic was thick tonight so I drafted a semi truck at 55 mph and averaged 47.2 mpg over 88 miles according to the scangauge... it's nuts, like 50-60 mpg when drafting at that speed!! But no fun at all, and not safe, but still impressive.
Old Jun 14, 2008 | 10:54 AM
  #1060
pcs0snq's Avatar
Was wondering if the AT Fit owners ever look at the MT MPG thread? I come over here now and than just to see how the AT's are doing.
