If i run rims with out TPMS ?
Old Jun 11, 2008 | 08:22 PM
Buzzbomb's Avatar
A computer fix seems to be the only possibility. Thanks to another member sending me the 07 electrical schematics, I compared it to the 08 and identified most of the wires in the gauge cluster harness. There were 2 that I could not identify but neither was for the TPMS that I could tell.
So that means it's ran by the computer along with several other warning lights.
Old Jun 11, 2008 | 11:37 PM
ToFit2Quit's Avatar
I spent $10 dismounting the tires off of my stock wheels. They removed the TPMS with it. It's an interesting little device. It looks like a little reflector stuck to the valve stem. I'm going to have them installed when I get new tires + ballance for my aftermarket wheels. I don't know if they have to be recalibrated though. I'll probably let you guys know the result in 2 months or whenever I finish wearing these tires out.... uhh... assuming that I don't forget about this thread. LOL
Old Oct 8, 2008 | 10:12 AM
madhatch's Avatar
its a sensor.. it reads a difference in tire pressure. I run 40lbs in mine no problems. When a oddy went low light came on.. I added air drove 2 blaocks light went off.. when the light came on agaon 3 days later i added air and it went off again.. i had the tire repaired and everything is great..
Maybe resetting the maintenence minder resets it on the fit....
Old Aug 30, 2019 | 08:26 AM
Fittenessdinyogirl's Avatar
PVC pipe trick sensor?
I was thinking of making a pvc cylinder to pressurize and put the tpms sensor in to trick the computer. I was planning on putting it right above the strut tower . Has anyone else tried this? I think it could work.
Old Aug 30, 2019 | 09:37 AM
Brain Champagne's Avatar
I think a piece of black electrical tape over the light is a lot less work. I did that when I had the spare on and the car passed inspection (it was a real spare, not the donut).
Sloto200
Mar 28, 2015 09:50 PM
Bustov
Feb 25, 2009 01:40 PM
jetscream
Jul 25, 2008 12:16 AM
fitster
Jun 3, 2008 04:06 PM
percy
Dec 10, 2007 03:37 PM
