Subwoofer install - Anyone have under the seat dimensions?
Old 08-31-2016, 09:55 AM
bensonr2's Avatar
I'm thinking about adding a sub, hopefully compact with built in amp.
Anyone have dimensions for under the seat?
I see various people have recommended the Kenwood. Though I see Pioneer also makes a similar unit though it looks like it has a larger footprint.
Old 08-31-2016, 12:00 PM
You know that the fuel tank is under the front seats right?
I have the Kicker powered sub, although there are many others out there too.
Old 08-31-2016, 12:08 PM
bensonr2's Avatar
Where did you install it and how much space did you have to sacrifice.
I talked with an installer and his opinion was the all in one units were not even worth it.
Old 08-31-2016, 12:27 PM
https://www.fitfreak.net/forums/3rd-...ml#post1341422
With the way I have this installed, my 8" powered Kicker sub is actually stronger than my 10" JL Audio Wedge sub using a conventional amp. The Kicker is 150w RMS (10% distortion) or 125w RMS at less than 1%.
Whereas my JL Audio is about 125w to 140w RMS based on the amps that I've used. Note that I have never installed my JL sub in my Fit, so I can't directly compare.
I like the remote gain (not bass boost) knob. Although I wish that it had the better gain/frequency knob in the Kenwood systems. The Kenwood is 75w RMS, whereas the Kicker is 150w RMS.
Old 09-01-2016, 11:30 AM
bensonr2's Avatar
Thanks for your responses.
Where exactly did you place the Kicker? The cargo area? If so did it prevent access to the spare tire and tools?
I guess part of my confusion was I saw in one of the existing threads the Kenwood was recommended. But looking at the pictures I see it was just placed on the floor behind the front seats.
Old 09-02-2016, 11:07 PM
I have full access to my tools. The only time that I need to disconnect the sub and remove my Frankenstein cargo cover, is when I need to access the spare.
The sub is literally hanging over the spare, but a bit towards the front of the car, so it's not in the way.
Old 10-10-2016, 11:11 PM
andre181's Avatar
My Kenwood KSC-SW11 fit perfectly under the passenger seat. Its pretty tight though, I'm not sure anything bigger would fit.
Sounds pretty good too IMO.
fitisno
04-24-2011 04:49 PM
ej20i
04-26-2010 05:12 AM
PHOENIX
04-16-2008 12:10 AM
ynot984
10-13-2007 08:53 PM
kkim
07-02-2006 01:18 PM
Quick Reply: Subwoofer install - Anyone have under the seat dimensions?
