64mm Throttle Body
Old Aug 26, 2008 | 11:20 AM
  #41
jits14's Avatar
does the WR intake manifold have a largerer inlet diameter?
Old Aug 26, 2008 | 11:31 AM
  #42
Sugarphreak's Avatar
Push My Button
I don't think it does, but I will have an opportunity to verify that this weekend.
I was thinking even with the reducer you are going to experence a big increase in throttle responce as the computer will be letting in more air than it expects. 35% open on a 64mm opening is a lot more air than 35% open on your stock TB.
Old Aug 26, 2008 | 11:33 AM
  #43
Push My Button
Can somebody verify this will work on a USDM Fit
Old Aug 26, 2008 | 01:42 PM
  #44
Tofuman's Avatar
if this works... someone should produce a quality reducer. it might make the intake piping a tighter fit against the battery though.
Old Aug 26, 2008 | 01:53 PM
  #45
Pedalpusher's Avatar
You bring up some good points. Since our cars have no air flow meter, the computer won't know about the extra airflow. There is a very good chance of running lean. This might make the car feel crisp and might yield better gas mileage, but could damage the motor.
Old Aug 26, 2008 | 02:37 PM
  #46
Push My Button
Except near WOT because of the restriction going into the manifold would keep the flow the same as stock.
Probably the Blitz throttle controller is a better choice then unless you modify the manifold... now if that was only 75$ like the junked BMW TB
Old Aug 26, 2008 | 03:54 PM
  #47
Masterdebater's Avatar
if someone can give me the year and which bmws it comes off (not sure if someone did) then ill look into this
Old Aug 26, 2008 | 03:59 PM
  #48
thomasgrant's Avatar
2001+ E46s with the 2.5L
Old Aug 26, 2008 | 04:24 PM
  #49
alf74's Avatar
- This TB is perfect for stock intake manifold
- WR intake manifold can't have a larger inlet diameter!
- Intake piping doesn't hit battery even with 2cm TB spacer (I tryed)
- Air flow meter??!!! Jazz/Fit has a map or tmap sensor! The car anyway doesn't run lean with this TB
- Blitz throttle controller is a game of 300$ and WR intake manifold for 500$ isn't worth, in my opinion..
To be precise this TB is only 0.90mm/1 cm larger than intake manifold inlet diameter (I'm referring to interior side of TB, not 64mm exterior). I built this "reducer" to avoid air hit this cm!!!
Old Aug 26, 2008 | 05:17 PM
  #50
Push My Button
I am pretty sure the Fit uses a combination of the MAF and the 02 to do fuel adjustments. I have a feeling you would end up running way too lean, for the same reason I was running lean when I installed my intake manifold. you should run a check on your AF to see what it turns up.
BTW I can assure you the WR intake manifold is worth it I recently out-pulled an RSX with no problem with an extra 200lbs of gear on the back of the car (in a safe controlled environment in case anybody... especially mods were wondering)
I will measure the inlet diameter of the WR intake this weekend, also have an opportunity to measure the stock manifold tonight to verify the claim it is a 54mm opening.
Old Aug 26, 2008 | 05:46 PM
  #51
Tofuman's Avatar
the base model RSX, right? from a roll?
Old Aug 26, 2008 | 06:12 PM
  #52
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Originally Posted by Injundon
2.5L Z3 and 2.5 and 3.0L Z4 all the same Part# : 13 54 7 502 445
the 64mm TB has nipples for coolant.
I looked this up and for 2002 the 2.5i has a different ending number 444 instead of 445.
Old Aug 26, 2008 | 06:16 PM
  #53
Posts in the NUUDE
This was not confirmed. That was my guess.
Old Aug 26, 2008 | 07:32 PM
  #54
Push My Button
Pretty sure it was a base, but was from a dead start and no RPM launch. I stayed ahead of him easily even with a shift. Those things must have outrageous RPM redlines because I was halfway through second before he shifted
Was just an interesting thing that happened, probably an novice driver or something.
Old Aug 26, 2008 | 07:42 PM
  #55
Posts in the NUUDE
The Type-S redlines at like 7800-8200rpms
Not sure what the base does. 6800rpms?
Old Aug 26, 2008 | 07:45 PM
  #56
jits14's Avatar
They are geared largein the 5spd, but they get through the gears almost as quick as a fit. He might not have been giving it wot.
Old Aug 26, 2008 | 07:58 PM
  #57
Posts in the NUUDE
Im sure he was. Bases are slow. :-/
Old Aug 26, 2008 | 08:08 PM
  #58
JamesBizzle's Avatar
wow... tagged for interest.
Old Aug 26, 2008 | 08:47 PM
  #59
Injundon's Avatar
if the plenum is ultimately 47mm all you will get is slightly quicker response and you'll have to use less pedal input for for the same airflow.
Old Aug 26, 2008 | 09:27 PM
  #60
jits14's Avatar
Based on some research on ebaymotors, it isn't this part model and corresponding bmw fitments. If you notice, the front looks a little different and the plug is different.
BMW 330i 01 - 05
BMW 330i 06 - 06 Cpe and Conv
BMW 530i 01 - 05
BMW X3 04 - 06 3.0L
BMW X5 01 - 01 3.0L
BMW X5 02 - 03 3.0L
BMW X5 04 - 06 3.0L
BMW Z3 01 - 02 3.0L
BMW Z4 03 - 05 3.0L
Our Part # : 337-60815-K70710
Our Inventory Notes : 3.0L,AT,RW
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/img]
the ebay picture could be wrong though...
It seems like its only the 2.5l one if someone can find a picture of it, but it might be a european version. I searched the bosch number the OP posted and it pulls up all european models like the alfa 156 and some audi models but its all in foreign languages.
