View Single Post
  #7 (permalink)
Old 10-05-2008, 12:57 PM
underdog underdog is offline
underdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to liveunderdog relies on Rep Points to live
Quote:
Originally Posted by kylerwho View Post
just put two head gaskets on to lower compression.
NOOOoo! that increases the piston to head clearance which reduces quench which could lead to detonation alot easier than just leaving it alone and spend more money on a professional tuner. there are several people out there that run high compression + boost with great results. look at all the boosted type R guys. they make the same hp as gsr's with typically 3-5 less psi and have a fatter power band.
its not always about lowering static compression. its about lowering dynamic compression! ie. cam timing, ignition timing, reducing backpressure(too small exhaust, turbine, ect....)free'er flowing systems will need less ignition timing to make the same power, thus reducing the chance of detonation but usually comes at a price. a little less boost response. however there are ways around that as well....twin scroll!!!
I will give you that lower compression gives you a buffer for mistakes. but the only way to do it right is custom pistons, or find a piston that works from another boosted engine with 73mm pistons 4 valves per cyl with same valve arangement. good luck.
__________________
2008 SSM Tanabe GF210 springs, Tanabe front strut bar, progress rear sway bar, Drag dr21's gunmetal, S2 short shifter & knob, Mishimoto intake, 8k hids, 4.3k fog's.
