DIY Oil Change 56k beware
Old Oct 4, 2008 | 09:59 PM
  #181
kevvur's Avatar
Originally Posted by DocB04
I didn't see a topic on this so I thought I would show a Step by Step on Changing your Engine Oil.
Disclaimer:
I am not a professional mechanic. This procedure is applicable to my personal Honda Fit 5sp and should not replace the training and judgement of a professional mechanic.
As you know Engine Oil is not something that last very long is you travel as much as I do. This is a Step BY Step procedure for changing your engine oil in a 2007 USDM 5sp Honda Fit. See pictures for help.
TOOLS / SUPPLIES: you will need 4 quarts of 5w-20 oil, 1 oil filter ( I used a Fram PH7317 oil filter with sure grip), an oil filter wrench (not pictured cause i didn't use one), and one 17mm wrench/ ratchet and socket combo.
Step one:
Pop your hood. Don't raise it yet just pull the lever.
Next ensure that your EBrake is Set so that your car doesn't roll when you raise it up on the jack/jack stands.
Next with a floor jack or OEM Jack Raise Each side of the front of the car and place jack stands on the jack points.
Now that your car is jacked up you can raise your hood. Lif the locking mechanism pictured below.
Raise the hood and lock in place with hood stand.
Now unscrew your oil fill cap. Ensure that the black rubber gasket is still on the cap and not left on the valve cover that way you don't lose it. If it has come off just simply place it back onto your filler cap and press it into place.
Now, place your oil catch bucket or bowl under the oil pan, use your 17mm wrench to remove the oil drain bolt and drain all oil contents into the bucket. The first picture shows the bottom of the oil pan and the oil drain bolt. Its cleverly labeled
Once the contents of your oil pan have been drained into your bucket you may replace the oil drain bolt. But first coat it with a thin layer of the used oil that way it doesn't get locked on the pan from the heat. Don't over tighten your drain bolt by tightening it with your wrench as much as you can just a few tightening turns should be plenty.
Now on the opposite side of the oil pan than your oil drain bolt is your oil filter. Position your oil catch bucket underneath your filter and slightly loosen the filter until oil starts draining from it. After a few moments remove the old oil filter and drain the remaining contents into your bucket. Also make sure that your oil filter gasket is not stuck to the oil pan (it is the black ring around the silver part of the filter in picture number 3).
Now grab your new filter and lightly coat the new filters rubber gasket with some old oil to prevent it sticking to the oil pan on your next oil change.
Place the new filter onto the filter threads on the oil pan and tighten as much as you can with your hands. You do not need to tighten with an oil filter wrench.
Now that your filter is on you can crawl out from under the car and start filling the engine with oil. The L15 found in the USDM Fit requires 3.8 quarts of oil. So, take your new 5w-20 oil and start filling through the oil fill area where you removed the cap earlier. Between quart bottles wipe away excess oil and spillage to prevent it from burning onto your valve cover (see picture 2).
Now that the engine has fresh oil inside replace your oil cap and tighten down hand tight, once again don't over tighten that way you can remove it next time.
Now go inside the cabin of your car and start it, ensure that none of the lights pictured below remain on or come of after starting the car.
Now to reset your oil life gauge that is combined with your trip meter, hold the button down for aprox. 10 seconds or until it starts flashing. Once it starts flashing release the button and then press it again and hold it for 5 seconds or until the "Oil Life" returns to 100%.
If you have anything that you feel needs to be added to this thread please post up and let me know and I will edit the thread to show the most possible correctness.
Thanks and Happy Modding
Clint.
Would it be possible to get those pics rehosted?
Old Oct 5, 2008 | 01:11 AM
  #182
clovis's Avatar
Check out amsoil, If you use their filter you can go 25,000 or 35,000 miles depending on which oil you use. More $ at first buy you save in the long run. check their web site, it shows all the independant testing.
awsome stuff. I'v been using it for many years.
Old Oct 6, 2008 | 05:50 PM
  #183
wow that's a lot of miles!
Old Oct 10, 2008 | 04:38 PM
  #184
looks like it's my turn this weekend. stopped by murray's and bought a case of M1 5W20 for $29.99. not the cheapest but not bad for $5/qt.
Old Oct 11, 2008 | 01:04 AM
  #185
nodrogkam's Avatar
get your oil from walmart. they are the cheapest usually when you buy per quart and especially if u buy 5 quart jugs. Of course other places can be cheaper with coupons.
They were selling the same stuff you bought for 30, for only 20. I think its $23 now.
I think i paid $20 for 4 quarts of 0w20.
Old Oct 28, 2008 | 03:10 PM
  #186
problem with the walmart jugs is that our cars only use 4qts.
i dont like leaving a opened 5qt jug in the garage. my G and MINI
takes 5qts so for those cars that's fine.
i prefer to have the 1qt bottles and use only the amounts needed.
keep the fresh spare bottle unopened until you have to add more
oil. but that's just me.
Old Oct 28, 2008 | 10:40 PM
  #187
F-IT!!!'s Avatar
where you get those headlights? shit looks tyte
Originally Posted by Fit of RAGE
i highly recommend NOT using synthetic oil during the first 10K miles. The reason is that with the synthetic oil, the engine will not "break in" properly
Old Jan 1, 2009 | 01:35 AM
  #188
vwli's Avatar
Oil Change on 2009 Fit Sports
I have not done any oil change on my 2009 fit sports yet. I have been using a custom made ramp (out of wood) which raise the car up about 4". Would it be enough clearance for oil change? It works for my 2002 Infiniti G20 sports which has a low body also.
Originally Posted by fm2n
It's quite simple. It's one of those things where once you try it, you'll realize how easy it is. Use gorilla ramps. Be sure to buy a self tightening oil filter remover/tightener. It's the kind where the more when you turn it, it tighter the grip gets. As for the oil drain screw, you should purchase on ebay a "FRAM SUREDRAIN" Our car uses size: SD-2. This will make life so much easier otherwise you end up spilling oil everywhere.
As for oil, you can use synthetic. In fact, check out Walmart. Their Castrol Syntec 5-20 5 quart jug is only $21.00 compared to paying $6.00 per quart of Mobil 1 5-20 synthetic. You'll be lucky to find Mobil 1 5-20 in a 5 quart jug.
People argue that synthetic shouldn't be used until 10,000 miles since a lot of deposits are still being released from the engine. Many other feel that 3,000 miles surpasses the break-in point.
Personally, what I used was Motorcraft 5-20 Synth-blend from walmart on my first change, that way I wont spend so much on removing the extra deposits. I drove it for 3,000 miles, and now I'm using all Castrol Synthetic with 7,500 change intervals.
Good luck.
Andy
Old Jan 1, 2009 | 01:50 AM
  #189
kancerr's Avatar
you dont need to jack up the fit at all. at least on my 07 i dont have to. i keep it on the ground, turn my wheel to gain extra clearance on the oil drain plug and its no problem.
Old Jan 1, 2009 | 02:24 AM
  #190
solbrothers's Avatar
im slammed, so i jack it up :P
Old Jan 15, 2009 | 01:28 PM
  #191
der Mond's Avatar
I changed to Mobil1 synthetic at 3K miles and no problem. I use Mobil1 filters (M-110) which are available at Wal-Mart. Wal-Mart has the best prices on Mobil1 synthetic also but has been having trouble getting it lately. My 1990 Honda Civic Si had Mobil1 after the first oil change and ran like new, no oil burning until I hit a moose with it at 282,000 miles. Synthetic oil reduces friction significantly, especially at cold-weather startup.
Old Mar 15, 2009 | 02:15 PM
  #192
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
drain bolt
Does anyone know the socket size for the oil drain plug for an '07?????
Old Mar 15, 2009 | 04:27 PM
  #193
kancerr's Avatar
are you kidding me...?
it states in the tutorial that you will need a 17mm socket...did you even bother reading the tutorial or searching or did you just decide to ask? RTFM!!
Old Mar 16, 2009 | 10:14 AM
  #194
pokems23's Avatar
tutorial
Simma' down. I figured there would have been pictures on the DIY, but supposedly they were deleted and I skipped through that page with the instructions. However, I am thankful for your help. Buy a puppy--it helps with the stress.
Old Mar 16, 2009 | 09:06 PM
  #195
kancerr's Avatar
i have a puppy hes right next to me right now. im not stressed out, its normal forum behaviour to search before asking...most people do it. i guess i did get a little over annoyed and should have been more polite just like you should have searched ;/ ....
  #196
kancerr's Avatar
https://www.fitfreak.net/forums/search.php
bookmark it, it will be your best friend...
Old Mar 16, 2009 | 09:11 PM
  #197
pokems23's Avatar
search
No problem. It's kind of ironic, but my puppy was next to me too when I wrote that message. I understand that it's just normal forum behavior. I do it too. Again, thanks for your help.
Old Mar 16, 2009 | 09:17 PM
  #198
kancerr's Avatar
np goodluck with your oil change. dont forget to recycle properly! ;P
Old Mar 24, 2009 | 01:40 PM
  #199
Papparock's Avatar
IMO Mobil1 synthetic is the only way to go. I have an 09 Fit Sport 5 speed and will change to Mobil1 on the first change about 3K. The car it replaced was an 03 Toyota Martix with 287K, never had anything but Mobil1 and those Wal-Mart oil filters. I ran the Mobil1 10K between changes-the old Toyota never leaked or used oil...amazing oil!!!
As long as you are in warranty, I would use Honda oil filters and keep the receipts. And just for the record, I'm not a big fan of Fram oil filters but they are manufactured by a company named Honeywell. Honeywell also makes Honda filters! (I'm sure to different spec's but still same company). The Honda dealer also advised me not to use Royal Purple...something about the formulation???
Old Apr 3, 2009 | 01:11 AM
  #200
mozarwasagenius's Avatar
filter only change
If I were to leave the drain plug and remove the filter would all of the oil drain out?
I'm asking because my other car does not and I think this is a nice feature especially if you are using synthetic oil and want to extend the oil change interval.
