Weapon R Secert Weapon Intake setup
Old Oct 31, 2008 | 06:15 AM
petwhookie's Avatar
So I just got the the intake in and I was wondering how you guys routed the 'cold air' tubing? I tried routing it through the hole by the headlight but it seems to be too small. How did you guys do it!
Old Nov 1, 2008 | 10:28 PM
petwhookie's Avatar
bump for interest:P
Old Nov 1, 2008 | 10:54 PM
kylerwho's Avatar
spoon fed
any pics would help. i think you have to move some wiring to make it fit or maybe grind out the metal to make it fit or you can crush the round tube to make it more oval to fit.
Old Nov 3, 2008 | 03:41 AM
petwhookie's Avatar
sounds like a shit load to do, ill take pics asap
Old Nov 3, 2008 | 08:30 PM
kylerwho's Avatar
spoon fed
its easier than it sounds. i will try direct you through it once pics are up so i can see what to do.
Old Nov 3, 2008 | 09:27 PM
TOOL's Avatar
I gave up on it.
I hate the Fitment of this intake. Horrible just like the WR products.
Old Nov 3, 2008 | 10:39 PM
petwhookie's Avatar
^ it is a bitch to put the intake on..
Old Nov 4, 2008 | 12:02 AM
kylerwho's Avatar
spoon fed
post some pics
Old Nov 4, 2008 | 12:35 AM
redrumm's Avatar
you can buy longer duct hose from an auto parts store. if all else fails dryer duct hose works if you wanted to get all DIY with it
Old Nov 4, 2008 | 12:57 AM
PHOENIX's Avatar
Hey guys i was looking into getting one of these but then saw what " TOOL " wrote so are these intakes not that good or is there just some crappy one out there ????
Old Nov 4, 2008 | 01:12 AM
kylerwho's Avatar
spoon fed
weaponr has some fitment issues with what seems like all their products. its kninda hit and miss. im not trying to disrespect their company but its what others have complained about.
Old Nov 4, 2008 | 01:20 AM
PHOENIX's Avatar
hit and miss huh guess ill hafta think about this one.......Thanx for the reply
Phoenix
Old Nov 4, 2008 | 03:09 AM
petwhookie's Avatar
Picture time!!!
So the problem was the "ram kit" WR supplied me with did not fit the hole (by the intake/near the driver's headlight). The ram kit was too big and I could not fit it without some elbow grease.
Here in this picture is how the intake sat normally. I was stumped how that ram kit was going to fit through that hole.
With some elbow grease, I moved the intake and the filter around. Flattened the ram kit a little and it all fit.
Butt dyno = no gains felt
Intake temp did drop 8 degrees according to my scanguage
Old Nov 4, 2008 | 08:36 PM
kylerwho's Avatar
spoon fed
wow. looks good. if you want a ram air effect take out the drivers side fog light and put the end of the hose in its place. you can expect even colder temps and more air ut you run a slight risk of hydro lock if its raining alot.
Old Nov 4, 2008 | 09:12 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I will. My race header was a piece of crap!
petwhookie; Id suggest removing that ziptie and the duct away from the airbag sensor.
Even thought it tapping against it shouldnt be enough force to cause the airbags to deploy I wouldnt risk it.
Old Feb 4, 2009 | 11:25 PM
WRLEO's Avatar
FYI the Ram air kit is a Universal Kit... It was made to allow you to place it where ever you wanted..
Old Feb 4, 2009 | 11:29 PM
WRLEO's Avatar
If you had problems.. I can always help you bro.. Who helped you at WR?
Dont Flame me.. Im just trying to help..
I would tie it up somewhere else.. BUt it does come with a bracket which you can use to mount the scoop in the front grill where it will get more airflow..
I did one on a fit.. was'nt as hard as you make it sound.. Maybe because i do this all day everyday.. Also i cant understand why i got Gains on the DYNO and you feel nothing... Are you Granny Shifting?? Or shifting at 3000RPM? Im not trying to knock you.. just a question.. I get people calling sometimes who shift at 3000rpm and say i dont feel anything... I mean how can you... You shift at 3000rpms...
If i can be of some help in the future just PM me... Im here to help..
EXCellR8
Apr 6, 2014 06:53 PM
Speedee 09 Fit
Aug 10, 2009 12:00 AM
jjninnottingham
Mar 24, 2009 07:02 PM
PR fit
May 30, 2008 03:00 PM
OneStopCustoms
20
Dec 16, 2007 07:32 PM
