Sponsored by:
Sponsored by: CARiD
Radio Reception.........raining?
Old Dec 17, 2008 | 02:26 PM
gimme's Avatar
Master FitFreaker
Thumbs down Radio Reception.........raining?
Just wondering if anyone else has ever had this issue. But EVERY time it rains, I lose radio reception for atleast one day after it has stopped raining. Has happened since I bought the car 2+ years ago when it was as stock as stock gets.
Old Dec 17, 2008 | 06:23 PM
gimme's Avatar
Master FitFreaker
yikes....no one i even asked Honda and got nothing but "it's because you installed a dvd plaver in your dash". It's even documented when it was stock
Old Dec 17, 2008 | 06:41 PM
fitoromocto's Avatar
Just last week mine when down, there's a Amplifier at the bottom of the antenna mast and water got thru .
If your signal come back after a couple day your Amp is still good thigh the screw at the bottom of the mast for a better water seal and should be good to go.
Old Dec 17, 2008 | 07:14 PM
trancedsailor's Avatar
I've had the car since April and haven't used the radio yet, and I even got the Spoon antenna rofl. Good luck finding the problem!
Old Dec 17, 2008 | 08:20 PM
gimme's Avatar
Master FitFreaker
dude, you may be my sanity saver! I will do it later. Thank you for the advice, i appreciate it.
Old Dec 17, 2008 | 08:35 PM
kylerwho's Avatar
spoon fed
up here in washington i get back reception every time its sunny out cause of so much rain. ha ha ha. i have no problems with it. if you have evidence of it getting bad signals before your aftermarket head unit then put the original back in and make them warrenty it.
Old Dec 17, 2008 | 09:43 PM
Tork's Avatar
I think you got to drop the headliner to actually tighten the base.
Dealer should do this for you! bBut taken apart, everything cleaned and dried, you could use some electrical conductor grease on the mast and base and you could silicone the base and gasket to the roof. That would be a permanent fix IMO
Old Dec 18, 2008 | 12:03 AM
gimme's Avatar
Master FitFreaker
so i went to check on my car...had some spare time. I opened the hatch, removed the weather stripping........water all over my headliner. WEAK!!!!!!!!!! no i have the glorious task of taking out the headliner..oh well, it needs a new pattern up there while I am at it, i may as well put some friggin insulation there too
Old Dec 18, 2008 | 08:36 PM
Jazz GD3's Avatar
whoa, this is something i should keep in mind. gimme, did that solve your problem?
also you removed the entire headliner? you say installing insulation between the headliner and the body, but would it get all damped and stuff due to the roof getting cold n such?
anyways that seems like a good idea. mind sharing how to take out the headliner if you did so? thanks.
Old Dec 19, 2008 | 09:57 AM
gimme's Avatar
Master FitFreaker
i haven't done it yet, but i have a loooooong vacation starting today. I will be off until Jan 5th.....so i will have plenty of time. As for the insulation...i am going to be getting the insulation that has the foil type exterior.
Old Dec 19, 2008 | 10:59 PM
explosivpotato's Avatar
Certainly hope that fixes it for you.. Honestly I rarely use my radio. The reception is terrible... I lose all of my Flint radio stations as soon as I get 20 miles away from flint...
Old Dec 23, 2008 | 03:38 PM
Saved's Avatar
If you guys are having problems with radio reception, you should look into an RC style antenna. I got mine from my friend's VW.
Old Jan 21, 2009 | 02:03 AM
jeandeau's Avatar
Yeah, me too. Reception was awful! The dealer (Alberta Honda) told me "Scratchy noise is normal in the city. No one listens to the radio anymore. Use the CD player like everyone else". Honest in front of God; that is what he said! When we continued to complain, he drove it around the block and said "A little bad reception is nothing to complain about and there is nothing abnormal about a scratchy radio. All the Fits are like that. Warrantee won't cover a problem if we don't hear a problem". I installed a 17" wire wrapped antenna. It helped immensely. Others have reported excellent results with installing the Toyota matrix antenna.
Old Jul 4, 2013 | 10:51 AM
mrpooh's Avatar
I myself just experienced radio reception failure (July 2, 2013).
And it was rainy out!
In scan mode, there was one station I got, sometimes, and then the radio searched through the frequencies and came up empty.
This is the first time I have ever experienced this.
My Google search brought me here again.
I have a 2008 sport and have had the car in my hands for a little less than 2 years.
There has been rain every day, but my car is under cover for some of it. And it has been humid. Extremely so, for days and days now.
I wasn't getting reception when I drove home from work, but it was picking up all the stations again the next day (a sunny day!).
Question:
Where exactly might moisture be getting in?
Where the antenna mounts to the roof?
Where exactly might I try sealing things up?
Thanks.
Darkstars
Mar 21, 2016 12:03 PM
granburysprint
Oct 5, 2009 04:47 PM
orion42
Jan 23, 2009 08:54 PM
gar1013
Jan 22, 2009 09:44 PM
bigtoepfer
May 22, 2008 11:10 AM
