eliminate daytime running lights
Old Mar 21, 2009 | 03:50 PM
paystein's Avatar
Smile eliminate daytime running lights
i bought a 2009 fit and i want to eliminate and it is easy only remove the fuse at the interior fuse panel, and thats all and now i can enjoy my hid kit, and dont have the DRL light on
Old May 30, 2009 | 02:48 AM
Lyon[Nightroad]'s Avatar
Bump! I was at a drive in movie theater and people started getting upset that my headlights would not turn off. I tried to explain they were DRLs but the people out in the middle of the country didn't understand the concept because none of the cars they drive have em. Is there a way I could have turned them off? I needed to keep the engine running to keep our little motorcycle battery from going dead. Its one of the drive-ins that broadcast on a fm channel.
Old May 30, 2009 | 08:58 AM
spreadhead's Avatar
If your battery goes dead from a few hours of using the radio, you have an electrical problem. I would be mad too if I was at a drive in and someone had his lights on!
Old May 30, 2009 | 10:02 AM
Fitting's Avatar
I'm glad my 08 didn't come with this feature.
More painful then useful.
My last car came with this feature but I was lucky someone figure out how to disable it.
Old May 30, 2009 | 08:27 PM
Today I learned that If you keep the E-brake engaged when you start the car - the DRL's will not come on until you release the E-brake. That would have helped out alot. I feel a bit stupid.
Old May 30, 2009 | 09:16 PM
Codger01's Avatar
Pull fuse # 15 - no DRL's. One of the first things I did.
Old Feb 28, 2010 | 01:43 PM
vtecfit1's Avatar
DLR noise (buzz)
back from the dead!!!
i installed the h4 high/low kit off my 07 fit onto my 2010 fit sport w/nav and even after pulling fuse 15 i get a buzzing noise up by the headlight (still need to track down exactly where its coming from) - has anyone run into this? the noise is only if the headlights are off, as soon as i turn them on the noise goes away.
o i did a search and can't find anyone talking about any type of noise. so i figured i'd post here before making a new thread
Old Feb 28, 2010 | 02:23 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
maybe it's the hid ballast?
justalilbit
Dec 16, 2018 01:15 PM
Irish
Jan 27, 2016 06:36 PM
j5ive
Canada Fit Forums & Clubs
18
Sep 16, 2014 01:52 PM
Orlandoech.com
Jul 2, 2010 01:35 PM
rickycbrjazz
Aug 3, 2009 03:06 AM
