Old Apr 17, 2009 | 02:20 PM
  #101
Shiro-san_Apeos's Avatar
Originally Posted by Committobefit08
I like the rims..but with the tires it reminds me of a rally car. How does it handle around turns with a bigger sidewall???
I want to know where you got the air scoop. That is pretty sweet. I wonder if the USDM will ever have that option or will yours fit the USDM??
Yes...You're right...that made my car looks like a rally or an off road car...lol... the tires profile is quite thick....But, in order to have a higher ground clearance, i Choose these tires... Roads in Jakarta are not very friendly hehehehe...and also, the building and basement parking lot, made me crazy...Using DF210, My Jazz's under parts, tend to hit the ground when facing bumpy and higher ground....
For the air scoop... as usual..it's MK Donz works...it's customized...
self made...and the placement is exactly above the brake fluid tank.
But I'm not quite sure whether it has same placement with the USDM type.
Do you notice that, there's some removable cover near the wiper? perhaps it covered the brake fluid tank... The air scoop replace the cover...
Old Apr 17, 2009 | 02:24 PM
  #102
Originally Posted by 1FiTpINOY
GUYS STOP QUOTING HIS POST LAWLZ!
If you are going to quote it, then at least take 5 seconds out of your life and erase the tags for the photos lol. I think his pictures are on here like 3 times >_<
You're right...it's too crowded...sorry guys if my pictures' bothering you all...
I don't know how to make a spoiler (so you don't have to see the pictures instantly)
Old Apr 17, 2009 | 02:32 PM
  #103
Committobefit08's Avatar
Originally Posted by Shiro-san_Apeos
You're right...it's to crowded...sorry guys if my pictures' bothering you all...
I don't know how to make a spoiler (so you don't have to seethe pictures instanly)
Its not you ...his comment was towards me because when I replied I quoted your comments and your pictures. Its fine to have your pictures...We applaud you for all the pics. I rather have too many then not enough.... A picture is worth a 1000 words.
Old Apr 17, 2009 | 02:33 PM
  #104
Originally Posted by dela
well on stock steelies, the tires are 185/65/15... so a 60 sidewall isnt TOO bad... im mostly going to daily drive my fit anyway so... maybe a track day a couple times a year... if any
i see...in here stock tires using 185/55/15 & 185/55/16
And mostly we change to 195/55/15 and 205/50/16...
Well...I do track day also no more than once every 3 or 4 months either...
Old Apr 17, 2009 | 02:37 PM
  #105
Hmmm I will have to talk to Donny and see how he made or where he got the scoop from.
Yes I believe there is a removable cover near the wiper by the brake fluid cap (next to the air intake inlet). I will have to look into that.
thanks
Old Apr 17, 2009 | 02:40 PM
  #106
I see...well i just installed the airscoop today, so i took the pictures today...
Thank you for the warm reception here...
anyway...goin' to bed now...it's already 2 am here... lol....
see you...
Old Apr 17, 2009 | 02:48 PM
  #107
vinn's Avatar
i ****in curbed my wheel today!
Old Apr 17, 2009 | 02:55 PM
  #108
That sucks!!!
My wifes tsx had some curb damage and I fixed it doing this...
DIY Fixing Curbed Wheels Rim Repair How To - 8th Generation Honda Civic Forum
Now it is barely noticeable. The average joe would never be able to tell.
Or you can just buy new rims...
I'm sorry. I know how it feels.
Old Apr 17, 2009 | 03:07 PM
  #109
Benggolf's Avatar
Wow...isn't that makes you tires profile is thicker using 205/60/15 ?
well, you'll get for comfort though...
I'm using Sustec Tanabe DF210 spring....
It's fulfill all my needs...from stability and comfort...still good enough for daily use and at circuit without having front & rear strutbar...
How much stiffer is the ride on DF210 over the OEM springs? Do you find it harsh or stiff enough to tell the difference?
Can you compare the ride between DF210 and Eibach Pro-Kit springs?
Thank you for your feedback!
Old Apr 17, 2009 | 03:10 PM
  #110
Benggolf's Avatar
Sorry to hear about that, Vinn. If the damage is really visible, you want to look into outfits in your area that repair alloy wheels. If done properly, it will look like new.
Up here in Vancouver, the cost of repairing an alloy wheel is about CDN$150.
Old Apr 17, 2009 | 03:16 PM
  #111
One very last answer before i go to bed
It's more stiffer DF210 over our OEM springs here...but not to much...it's still tolerable... it's still comfortable enough with much more improve handling...
Between DF210 and Eibach Pro-Kit springs?? Let's just say, Eibach Pro-Kit springs is in the middle between DF210 springs and OEM springs...
Not too lower and not too stiff...but still much improve handling than OEM...
It' your choice. MK Donz was using Eibach pro-kit springs...
Now he's using NF210. It's nearly the same with Eibach pro-kit.
Thanx...
Old Apr 17, 2009 | 03:23 PM
  #112
Benggolf's Avatar
Now he's using NF210. It's neraly the same with Eibach pro-kit.
Thanx...
Thank you for taking time out to answer my concerns!
Have a good night's rest. +Reps for you!
Old Apr 17, 2009 | 10:29 PM
  #113
1FiTpINOY's Avatar
There in fact is a removable part but its the opposite side >_<
Is your scoop mated to your intake as well?
LOL no no silly I appreciate you posting pictures. I was just saying for the other two members who quoted your pictures, so the page was showing your pictures three times
But no way man, you're Fit looks amazing. loving the Volks to the max!!!
Old Apr 18, 2009 | 12:13 AM
  #114
No, the scoop is as simple as plug and play
just remove the removable cover:
(pics)
the original removable cover
Airscoop
Thanx Man...by the way...
Old Apr 18, 2009 | 12:17 AM
  #115
1FiTpINOY's Avatar
Hmmmm..... If your intake is on that side then it would have been great to have the scoop feed right into the intake like Group M's. I'm not sure about the Fit but they have a similar style for the civic and it's pretty sick
Old Apr 18, 2009 | 12:32 AM
  #116
well...the intake is near with the scoop...because the intake manifold (header) is on the driver side (right side).
Does your intake on your left side? or right side? The removable cover is upper the brake fluid cap...
Old Apr 18, 2009 | 02:13 AM
  #117
Benggolf's Avatar
That air scoop is great Shiro-san_Apeos!
Hope you don't mind sharing where you bought that air scoop and the part number. TIA.
By the way, are the cars LHD (left hand drive) or RHD in Indonesia?
Old Apr 18, 2009 | 06:01 AM
  #118
1FiTpINOY's Avatar
It probably wouldn't matter bengolf unless you plan to modify it for us I'm pretty sure it's going to have to be altered so that it fits on the other side of the hood.
Old Apr 18, 2009 | 11:50 AM
  #119
1FiTpINOY was right...it's self made...
Indonesia is RHD...
You could modify yourself...maybe you could ask a sample to MK Donz, so you might try to make or modify it to be fitted on the left side..
Old Apr 18, 2009 | 12:27 PM
  #120
Benggolf's Avatar
Thank you for your reply Shiro-san_Apeos. Perhaps, one day when I run out of bolt-on projects.
