Old Jan 21, 2014 | 07:13 PM
  #10101
connor55's Avatar
Originally Posted by DA K Cudder
I actually spend the good part of an afternoon testing the system out. When i fitted and tested the lights before I put the front lens on, both worked just fine. But once the lens went back on it started to have problems. I changed the grounding point, even grounding it directly to the same point as the other light. The passenger side was the side having the issues. The bulb on that side never worked once the issues began. But the ballast would randomly work on the driver side bulb, but only is both ballasts were plugged in. Its a weird issue.
Did you have the bulb in the projector when you put the headlight back in the oven?
So in other words, your passenger side bulb doesn't work on either ballast, and the drivers side bulb works on the passengers side only intermittently?
Old Jan 21, 2014 | 07:24 PM
  #10102
DA K Cudder's Avatar
Yes bulbs were in when I put the headlights back in the oven. I finalized the position of everything and locked it all down before I baked it.
Yes that is correct.
Old Jan 21, 2014 | 07:35 PM
  #10103
connor55's Avatar
Well the d2s bulbs should just clip into the back of the projector, so I don't think it's really necessary to have them in the oven at any point. It's not like the bulbs themselves need to be lined up.
I can't help thinking that maybe it was a mistake to put the bulbs in the oven and that that was what killed one of them.
Old Jan 21, 2014 | 08:08 PM
  #10104
blassty's Avatar
Cool
Originally Posted by EnticedByTiffany
I cannot say enough how AWESOME(!!!!!) of a job John at JDP Engineering does. He was nice enough to wrap the winglets and made them flawless and seamless. LOVE!
All I got for now
These look great!
Old Jan 21, 2014 | 10:48 PM
  #10105
I hope thats not what caused the problem. I was following their youtube channel's D2S install, and as far as I could tell they left the bulbs in the rest of the time after they were installed into the projector, and the video doesn't mention having to take the bulbs out.
Old Jan 22, 2014 | 12:11 AM
  #10106
xxryu139xx's Avatar
all the guides i've read said to remove anything metallic before putting in the oven... but that's probably to make sure it doesn't burn the headlight. then again i'm sure the aluminum on the lightbulb would burn the bulb..
Old Jan 22, 2014 | 12:35 AM
  #10107
Well I figured since the HID bulb itself gets hotter then 300 degrees that it could handle a 7 minutes in a 270 degree oven. I mean this link H1 Bulb Operating Temperature (and other properties) Comparison - Page 6 shows that the bowl and shield itself gets past 300 degrees. So I think the bulb can handle the temp.
Old Jan 22, 2014 | 08:28 PM
  #10108
CMartinez's Avatar
Got my roof wrapped today
[IMG][/IMG]
Old Jan 22, 2014 | 08:46 PM
  #10109
Goobers's Avatar
Today, i popped a CEL on my Fit. Sigh.
Old Jan 22, 2014 | 09:00 PM
  #10110
Waiz's Avatar
Avid FitFreak Poster
[IMG][/IMG]
Looks great Chris!
Old Jan 23, 2014 | 12:36 AM
  #10111
CMartinez's Avatar
Originally Posted by Waizzz
Looks great Chris!
Thanks Waiz! Cant wait for the next meet
Old Jan 23, 2014 | 12:50 AM
  #10112
ckarlosz95's Avatar
Where can i get that lights ?
Old Jan 23, 2014 | 09:28 AM
  #10113
Wanderer.'s Avatar
[IMG][/IMG]
That does look good
Old Jan 23, 2014 | 10:18 AM
  #10114
Black3sr's Avatar
[IMG][/IMG]
Nice. Mined got wrapped in white again last night - Snow that is.
How much to wrap a roof?
Old Jan 23, 2014 | 10:42 AM
  #10115
CMartinez's Avatar
Thanks guys! I appreciate it. It cost me about $150, but I guarantee you can do it yourself for way cheaper.
Old Jan 23, 2014 | 11:26 AM
  #10116
camivill's Avatar
Cleaned Engine, changed couple of coils
Very happy with power regained by the Engine, will do some cleaning inside with gas additives before changing the oil....
Old Jan 23, 2014 | 11:31 AM
  #10117
dvleucsd's Avatar
lookin' Good!
Old Jan 23, 2014 | 02:44 PM
  #10118
MEATBABY's Avatar
Wow how many miles on your engine? Changed my plugs a couple weeks ago at 104k miles and my coils didn't look like that at all.
Old Jan 23, 2014 | 05:47 PM
  #10119
connor55's Avatar
^ maybe it has to do with the pollution in china?
Old Jan 23, 2014 | 07:29 PM
  #10120
Waiz's Avatar
That was one dirty engine too, good job cleaning it
