I like the rims..but with the tires it reminds me of a rally car. How does it handle around turns with a bigger sidewall???
I want to know where you got the air scoop. That is pretty sweet. I wonder if the USDM will ever have that option or will yours fit the USDM??
Yes...You're right...that made my car looks like a rally or an off road car...lol... the tires profile is quite thick....But, in order to have a higher ground clearance, i Choose these tires... Roads in Jakarta are not very friendly hehehehe...and also, the building and basement parking lot, made me crazy...Using DF210, My Jazz's under parts, tend to hit the ground when facing bumpy and higher ground....
For the air scoop... as usual..it's MK Donz works...it's customized...
self made...and the placement is exactly above the brake fluid tank.
But I'm not quite sure whether it has same placement with the USDM type.
Do you notice that, there's some removable cover near the wiper? perhaps it covered the brake fluid tank... The air scoop replace the cover...
I don't know how to make a spoiler (so you don't have to see the pictures instantly)
And mostly we change to 195/55/15 and 205/50/16...
Well...I do track day also no more than once every 3 or 4 months either...
Yes I believe there is a removable cover near the wiper by the brake fluid cap (next to the air intake inlet). I will have to look into that.
thanks
Thank you for the warm reception here...
anyway...goin' to bed now...it's already 2 am here... lol....
see you...
That sucks!!!
My wifes tsx had some curb damage and I fixed it doing this...
DIY Fixing Curbed Wheels Rim Repair How To - 8th Generation Honda Civic Forum
Now it is barely noticeable. The average joe would never be able to tell.
Or you can just buy new rims...
I'm sorry. I know how it feels.
Wow...isn't that makes you tires profile is thicker using 205/60/15 ?
well, you'll get for comfort though...
I'm using Sustec Tanabe DF210 spring....
It's fulfill all my needs...from stability and comfort...still good enough for daily use and at circuit without having front & rear strutbar...
Can you compare the ride between DF210 and Eibach Pro-Kit springs?
Thank you for your feedback!
Sorry to hear about that, Vinn. If the damage is really visible, you want to look into outfits in your area that repair alloy wheels. If done properly, it will look like new.
Up here in Vancouver, the cost of repairing an alloy wheel is about CDN$150.
It's more stiffer DF210 over our OEM springs here...but not to much...it's still tolerable...
it's still comfortable enough with much more improve handling...
Between DF210 and Eibach Pro-Kit springs?? Let's just say, Eibach Pro-Kit springs is in the middle between DF210 springs and OEM springs...
Not too lower and not too stiff...but still much improve handling than OEM...
It' your choice. MK Donz was using Eibach pro-kit springs...
Now he's using NF210. It's nearly the same with Eibach pro-kit.
Thanx...
One very last answer before i go to bed
Now he's using NF210. It's neraly the same with Eibach pro-kit.
Thanx...
Thanx...
Have a good night's rest.
+Reps for you!
Is your scoop mated to your intake as well?
LOL no no silly
I appreciate you posting pictures. I was just saying for the other two members who quoted your pictures, so the page was showing your pictures three times
But no way man, you're Fit looks amazing. loving the Volks to the max!!!
There in fact is a removable part but its the opposite side >_<
LOL no no silly
LOL no no silly
just remove the removable cover:
(pics)
the original removable cover
Airscoop
Thanx Man...by the way...
Hmmmm..... If your intake is on that side then it would have been great to have the scoop feed right into the intake like Group M's. I'm not sure about the Fit but they have a similar style for the civic and it's pretty sick
well...the intake is near with the scoop...because the intake manifold (header) is on the driver side (right side).
Does your intake on your left side? or right side? The removable cover is upper the brake fluid cap...
That air scoop is great Shiro-san_Apeos!
Hope you don't mind sharing where you bought that air scoop and the part number. TIA.
By the way, are the cars LHD (left hand drive) or RHD in Indonesia?
Indonesia is RHD...
You could modify yourself...maybe you could ask a sample to MK Donz, so you might try to make or modify it to be fitted on the left side..
