apexi neo or aem f/ic?
Old Apr 30, 2009 | 12:51 AM
  #41
explosivpotato's Avatar
OK I did some research and I think I see how they did this.
MAP signal controls timing as well as fuel for our cars. The F/IC allows you to remap the MAP signal based on load / RPM.
By pulling MAP voltage, you effectively pull fuel AND add timing (via the stock maps). You can add the injector pulsewidth back in directly using the main fuel map, and your net result is advanced timing. You'd have to use some sort of OBD 2 monitor / logger to ensure you aren't adding too much / not enough timing, however, as the FIC can't datalog ignition timing.
So, by ghetto-rigging it, you CAN run advanced timing with the F/IC.
Hm... I might try implementing a lean cruise with this... Advanced timing + lean mixtures at cruise loads can make for some ridiculous gas mileage.
Old May 1, 2009 | 05:38 PM
  #42
im the fit's Avatar
can someone please explain what the load does in map load with the F/ic
Old May 1, 2009 | 11:29 PM
  #43
im the fit's Avatar
and do I need to use the on board map on the fic foe N/A?
Old May 1, 2009 | 11:51 PM
  #44
Manifold pressure is a measurement of engine load. All fuel maps for speed density cars are plotted against RPM and Load (MAP).
And yes, you need the on board MAP sensor. The FIC uses it for the load calculation.
Old May 1, 2009 | 11:55 PM
  #45
im the fit's Avatar
alright one last question before I install on saturday what do I connect that hose to
Old May 1, 2009 | 11:58 PM
  #46
The hose is vacuum line. It's for the MAP sensor nipple on the front of the FIC. It goes to any vacuum source off the intake manifold.
leonine
187
Aug 5, 2017 08:08 AM
pbz08gd3
Sep 8, 2009 03:41 PM
im the fit
Aug 26, 2009 10:46 PM
1990hondahf
Jul 18, 2009 04:30 PM
integradriv3r
Jul 31, 2006 12:04 PM
