GE8 Lowered Thread - Post your pics!!!
Old Apr 30, 2009 | 09:25 PM
JPGC's Avatar
Eibach Pro Kit pricey? Got mine from Tirerack for $217.00 shipped!
Old Apr 30, 2009 | 09:38 PM
Scaldy's Avatar
Originally Posted by Choro-Q_Fit
Is T1R working on a Damper kit to go with the springs?
Coming from the VW world I'm scared to lower my car as much as the DF's and T1R's on the stock dampeners. The mk4 VW dampeners use to bottom out and die quick with any serious drop; plus the ride wasn't very flattering .
The Eibach's were what I was leaning towards before my visit to AJR because of wanting to use the stock dampeners. Now I'm not sure. The T1R drop was very very nice with 17" Volks.
Old Apr 30, 2009 | 09:56 PM
qbmurderer13's Avatar
I don't consider 1.3" a serious drop. I'm on DF's and the ride is equal to or better than stock. Doesn't feel harsh or bouncy and the shocks don't bottom out. The ride is actually smoother than stock with my springs.
Old Apr 30, 2009 | 10:18 PM
superfriend's Avatar
Originally Posted by projekz
Here it is---T1R S coils
Well now, that's damn near perfect.
The price doesn't hurt either, seeing as it's the lowest of all these options.
Old Apr 30, 2009 | 10:26 PM
dela's Avatar
Originally Posted by AJ PwR Jr.
We are R&D'ing the GE8 S-Spec damper now and should have something ready before summer
can't wait!!!!
Old May 1, 2009 | 12:02 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
Originally Posted by kenchan
looks good guys. yah, tanabe has a werd taste of making most of their springs so that the rear sits low. not ideal at all on a fwd car.
Originally Posted by superfriend
I had really intended on getting DF210s initially. However, the more I compare them to the drops some of the other springs have to offer, the more I dislike them. Looks like the nose of the car is pointing up - not a very aggressive look. What's worse is if you put actual weight back there.
Originally Posted by luv4jdm
Judging from the pics it does look like the tanabe's are pointing up. Hmmm, nvm about getting tanabe's I might just get the RSR or the Eibach...
after seeing in person both my car and qbmurderer13 car.
most def tanabe sit lower in the back than mine.
also mine sits lower in the front than tanabe.
look at these pics
SSM has RS*R
TW has Tanabe DF210
Old May 1, 2009 | 12:39 AM
Scaldy's Avatar
look at these pics
SSM has RS*R
TW has Tanabe DF210
This is turning out to be a great thread. Very informative.
Well, with only a .1 difference between the T1R and the Eibach's I'm sure either one will be fine. I also use my rear seats for 2-3 passengers often enough that I don't mind being a little higher in the rear.
T1R F-1.3 R-1.5
Eibach- F-1.2 R-1.4
Compare to: Tanabe DF210 F-1.3 R-1.8
Old May 1, 2009 | 01:59 AM
Benggolf's Avatar
Originally Posted by kevvur
$225??
Website says $199CAD
Well, that was what Jason told me. Perhaps it was just an estimate as there was no firm pricing then.
Old May 2, 2009 | 12:41 AM
fittybux's Avatar
regarding the tanabe springs making the back look "lower" than the front...most cars have larger front wheel well arches than the rears. this could be a factor in why it may look a certain way. springs alone are just for looks anyways...
nice pics though!
Old May 2, 2009 | 01:15 AM
Benggolf's Avatar
T1R F-1.3 R-1.5
Eibach- F-1.2 R-1.4
Looks like the T1R springs are the right ones for you.
Only thing I am not so sure about is how much stiffer it really is over OEM.
If they ride anything close to the Eibach Pro-Kit, then they will be great in IMHO.
After lowering 3 cars of ours with Pro-Kit springs, I have decided to try the Tanabe DF210s.
My problem now is to find the wheel style I like with right offset to eliminate any possibility of fender rub.
Old May 2, 2009 | 12:19 PM
panda1314's Avatar
added Tein and RSR info. Mod would you be kind enough to make this a sticky?
Old May 2, 2009 | 01:26 PM
  #32
niko3257's Avatar
Just so everyone knows my RS*R's are lower than that. 1.1F 1.5R
Old May 2, 2009 | 03:25 PM
  #33
projekz's Avatar
I'd like to add that the T1R springs are pretty comfortable for daily driving.
Old May 2, 2009 | 05:05 PM
  #34
panda1314's Avatar
i pulled the specs from RSR's japan website but it does look a lot lower in your pictures. Maybe someone else about to install RSRs can take some before and after measurements
  #35
Benggolf's Avatar
Projekz, have you had any experience with DF210s? Just wondering if you can compare the ride between the T1R, DF210 & Pro-Kit. TIA.
Old May 2, 2009 | 06:35 PM
  #36
projekz's Avatar
Sorry, no experience with Tanabe springs at all. I've had Tein, H&R, Eibach and T1R and I would say that the T1R are comparable to Eibach Pro Kit comfort wise. I really like my T1R springs. Had the car loaded with suitcases and the ride level still good and they didn't bottom out.
Old May 2, 2009 | 06:41 PM
  #37
Benggolf's Avatar
Thanks for sharing.
Old May 2, 2009 | 09:26 PM
  #38
Committobefit08's Avatar
Before...
After... (Tanabe Df's)
Old May 2, 2009 | 10:48 PM
  #39
MugenAP2's Avatar
I just purchased the T1R today. I can't wait to get them in! Now all I need is some wheels!
Old May 3, 2009 | 09:31 AM
  #40
EK3 Ferio's Avatar
Espelir Super Active Down Ride Height Drop: F 1.2 in / R 1.6 in Spring Rates: F-2.4kg/mm / R-2.3kg/mm
Before...
After...
