GE8 Lowered Thread - Post your pics!!!
Old May 11, 2009 | 11:14 PM
  #81
Bariki's Avatar
So it seems like the RSR and Eibach are closest to stock springs ...
I would like to lower, but I still want to be able to load my car up and also not worry about my dampers or ride quality...
Am I right in assuming that these choices are best, or is there something better for stock feel?
Old May 11, 2009 | 11:27 PM
  #82
Tork's Avatar
Originally Posted by MugenAP2
RS*R Ti2000 specs are...
GE8 Fit RS 5MT (drop of 25~20mm in the front with a spring rate of 2.26kg and 25~20mm in the rear with a 2.32kg spring rate).
25mm is about .98 inches.
I seem to remember AshPanda as having the RS*R Super Downs. Correct me if I am wrong.
Nick and I have the Down spring.
Old May 25, 2009 | 11:01 PM
  #83
superfriend's Avatar
T1R S-Coils.
Before:
After:
A few other pics, since it's been a while that I've posted.
Old May 25, 2009 | 11:22 PM
  #84
danielg's Avatar
Nice! Great shot of the T1R
Old May 26, 2009 | 02:34 AM
  #85
LaZyBoI's Avatar
I don't have very many pics nor are they very good pics.. but these are before:
After on Hipermax S-Compact.. (was trying out the BBS)
Old May 26, 2009 | 02:49 AM
  #86
Benggolf's Avatar
Here's my SSM, lowered with Tanabe DF210.
I would like to say thanks to all of you that helped me though the process of deciding what springs to buy.
Am very pleased with the drop and how the car still rides comfortably with OEM wheels/tires.
Old May 26, 2009 | 02:58 AM
  #87
Benggolf's Avatar
Hi LaZyBoI,
The Hipermax S-Compact looks good on your car! What's the rim size/offset/tire size? I suppose that the wheels are powder coated bronze paint.
Nice, nice!
Beng
Old May 26, 2009 | 03:01 AM
  #88
danielg's Avatar
MOAR MOAR MOAR MOAR MOAR MOAR MOAR MOAR
Are those from HKS USA or HKS Japan? How low do they go?
Old May 26, 2009 | 12:11 PM
  #89
LaZyBoI's Avatar
HKS USA :x
HKS USA Hipermax S-Compact
Originally Posted by Benggolf
Hi LaZyBoI,
Nice, nice!
Beng
They're actually just sprayed Wheel spec.. I rub like there's no tomorrow and looking into some new wheels :x but 17x7 +42, 415/40
Old May 26, 2009 | 10:09 PM
  #90
Lek's Avatar
Lek
My friend has a fit with Mugen LG body kit and is looking to lower a little.
He's loking at the RSR Suspension Coil with a slight drop because he only has 160mm of ground clearance on the front with stock springs, 16" mags and Mugen LG body kit.
He's a little worried the car may lower more than the manufacture specifications. How much sag will usually occure in time?
Maybe someone can help.
Old May 26, 2009 | 10:59 PM
  #91
danielg's Avatar
Depends on the springs. Some will "sag" lower than more. I don't have experience with RSR springs, but like most springs I would assume .25 - .50" lower after it settles.
On a side note, I was going to order the HKS coilovers today, but after checking the specs, it says 40mm or 45mm drop in the front? The car above looks pretty low to me, doesn't look the specs listed by HKS.
Lazyboi - Are you all the way down? If not, how much lower can you get? Thanks man.
Old May 27, 2009 | 01:04 AM
  #92
niko3257's Avatar
FitFreak GE8 DIY Guy
the RS*R's will not sag much. they come pre settled already.
i personally have had my set a long time and still the same.
Old May 27, 2009 | 02:36 AM
  #93
LaZyBoI's Avatar
I think I can drop another inch in the front and rear.
Old May 27, 2009 | 04:09 AM
  #94
danielg's Avatar
really?!?!?! Can you post more pics of how low you are right now? You look pretty low, but there's a shadow so i cant see the wheel gap.The back still looks a little high up though...looks like another inch in front would tuck tire, and in the back would bring you to a finger gap?
Sorry for all the questions.
Old May 27, 2009 | 05:56 AM
  #95
Lek's Avatar
Lek
[QUOTERSR Suspension Coil Drop F-0.8 in / R-1.0 (???) in Spring Rates F- 2.26kg/mm/R-2.3kg/mm ][/QUOTE]
I have been looking everywhere to get a set of these. Does anyone know where to buy them?
Do you think the US spec is the same as Asian spec and what is the OEM K spring rate compared to RSR Suspension Coil.
Old May 27, 2009 | 09:53 AM
  #96
515's Avatar
515
Old May 27, 2009 | 11:35 AM
  #97
projekz's Avatar
^^ Sick...You wouldn't make it out of my driveway but SICK!
Old May 27, 2009 | 12:19 PM
  #98
Benggolf's Avatar
Wow, does it still have a "suspension"?
Old May 27, 2009 | 12:53 PM
  #99
danielg's Avatar
Awesome stance above!
Old May 27, 2009 | 05:51 PM
  #100
MugenAP2's Avatar
Of course it does... It is a full body coilover!
