Engine Build Thread
Old May 9, 2009 | 08:56 PM
Midnightfit's Avatar
Engine Build Thread
I have had my block looked at by my engine builder
1. the head can be ported but only lightly
2. Cat Cams makes cams for our engine
3. The block sleeve are just like b16 sleeve; so running any more then 10 psi you will run it to problems
4. stock pistons and rods are not bad for what they are.
5. cryo treating or wpc treating rods and piston would be a better option then forged product based on the sleeve would go before the stock one would.
6. Stock hardware is weak (rod bolt and so on)
7. head gasket is ok
8. Crank is fine
Ok I am planning to rebuild my engine with in the year.( i have alot of miles)
I am going turbo of supercharger
I want the rebuild done at the same time as the turbo install so they break in together.
I am going to contact arp about getting stock replacement bolt made up for our engine.
Also a metal head gasket manufacturer about making head gasket for our engine.
Also may have a my a bored out t/b with new butterfly
Old May 20, 2009 | 03:20 AM
kevkor2002's Avatar
Good info. What are your number goals for the car? 200? 250? More?
Old May 20, 2009 | 09:57 AM
DrKelso's Avatar
I believe Josh (Gd3kamiwanab) was running higher than 10 psi for a while before he blew his motor.
When the motor did blow, it wasn't the sleeves...I believe it was a connecting rod shooting through the side of the block
Old May 20, 2009 | 10:29 AM
dewthedew's Avatar
yeah you should really just read joshes thread.
Old May 20, 2009 | 11:46 AM
DrKelso's Avatar
in either case, this should be good
. : Edit : .
saying this sentence with an Italian accent is a lot of fun
. : Edit v2.0 : .
I love your avatar. Obammunism FTL
Old May 20, 2009 | 07:03 PM
yeah I have read that thread and I am still not sure about the sleeve. I hope he doesn't run into problem but when i send the money I will go all out
Old May 20, 2009 | 07:10 PM
dewthedew's Avatar
becareful with the TB ray did his and ended up getting a new one.
Old May 20, 2009 | 07:50 PM
The reason it didnt work because he need a new butterfly valve cut
siguy
Dec 21, 2015 06:13 PM
hehn
40
Jan 22, 2014 05:43 PM
taloot y2k
Dec 28, 2010 10:37 PM
Midnightfit
13
Apr 21, 2008 09:46 PM
Mr_ET
Apr 19, 2008 04:50 PM
