HID Install Problem
Old May 24, 2009 | 10:20 PM
setter11's Avatar
HID Install Problem
So i bought a H11 kit from HIDExtra.com - The Best Source for HID Xenon Light Conversion Kits
install was a breeze since i have installed a few HID kits
in my day...
after install i take my baby out for a drive to see the lights in action
i get to my garage get off to gaze at a beautiful thing and one of the lights is
off, i turn them off then on again now the one that was off is on and the other that was on before is now off... i turn lights off again and then back on and finally they work again...
Now, they turn on but at first the dont turn the proper color, GOLDEN YELLOW... in order for them to reach the desired color i have to turn them on, then off, then on again...
Help Please....
Old May 25, 2009 | 12:01 AM
1FiTpINOY's Avatar
It's because you got a stupid plug and play kit. You were deceived by brightness and looks instead of aiming for true OEM quality
Old May 25, 2009 | 12:14 AM
setter11's Avatar
haha, touche!
that sounds about right....
i had 55 watts bulbs in there and they were great
but you cant beat the output of HIDs...
Old May 25, 2009 | 02:58 AM
1FiTpINOY's Avatar
Originally Posted by setter11
haha, touche!
Can't beat the output plug and play kits!?!?!? Are you serious??
.................Here's a picture for reference
You tell me what has better output
Old May 25, 2009 | 04:14 AM
713_fit's Avatar
well those are two different colors..comapre the same color and it be a better comparison
and you have to let the HIDS warm up before they get to their true colors..i have yellow hids in my fog too..they are green also at first until they warm up
you might want to double check ur connections to make sure they are all good and not loose which could cause them to turn on and off..or one off and one on..and etc
Old May 25, 2009 | 02:23 PM
hidextra.com's Avatar
for the turn on turn off issue, please make sure all plugs are clipped properly. if it still not solve the problem, give us a call, we will get more info about the issue and maybe sending you some capacitor wires to have it function properly.
can you also advise what type of H11 kit did you purchase? the 3000K?
if you have the 3000K, for the first 10~15 sec, the color will change from bluish green to golden yellow, that is just how the HID bulbs works. HID bulb do need to be warmed up to reach to its correct color temperature.
let us know if you have any other questions.
thank you
Old May 25, 2009 | 02:24 PM
setter11's Avatar
Yes, that is what i said, you cant beat the out put of a "plug n play" kit...
Now, you may possibly be interpreting me saying "output" as in the beam pattern, which of course is going to be better OEM, but the Honda Fit does not come stock with HIDs, so using it in my term of "OUTPUT" which is being used as the amount of light given off by the HIDs is greater then stock bulbs...
Originally Posted by 713_fit
well those are two different colors..compare the same color and it be a better comparison
Yeah, that would be a definitely be a better comparison...
Oh, yeah i know about letting them warm up, i tried it last night and i guess it was just because it was the first time they were being used that it took them awhile...
i took apart my bumper and disconnected and re-connected all of the connections... have not had the same problem yet... Thanks for the response...
Pics:
Halogen ---> HID comparison
The change is visible... This kit is ACTUALLY 3,000 K not 3,500 K
Only fogs on (no headlights) sorry its blurry [CELL PIC]
overall, the product is GREAT!!!
Old May 26, 2009 | 12:25 AM
713_fit's Avatar
np..glad i could help =)
Old May 26, 2009 | 01:11 AM
1FiTpINOY's Avatar
Again, you fail to realize you are being fooled. Just like everyone with these kits, you feel the difference is in colors.
The color temperature does not affect the way the light is distributed. If the temperature were the same 4300K, it would sitll be scattered all around just as it shows in the picture
Nope. I referred to output as the fully efficient and functional distribution of a retrofit. And even in your terms of "OUTPUT", the amount of light given off by plug and play kits is not greater than stock bulbs, again, you are being fooled by the color of it.
Fact is plug and play kits in halogen headlight housings just don't mix. The HID technology is not designed for the reflective housing, it is designed for a projector housing
And I'm not trying to be an asshole, I'm seriously trying to lead you to the right way, for both the sake of your knowledge and your life......
Old May 26, 2009 | 01:44 AM
setter11's Avatar
That is greatly appreciated...
If in fact these were going into headlights, i would see the scatter and all being a major problem, but seeing as how i am using the kit for fogs and for show, i think the plug and play kit are great for that...
if i were to being doing it for SAFETY and BETTER Driving conditions then i am full of it...
plus RETRO Fit is out of the QUESTION...
i dont feel like dropping the much $$$ into headlights
Old May 26, 2009 | 02:18 AM
moegenki's Avatar
Did your problem stop completely? I'm having the same issue with mine except I need to flash my highbeams once or twice to turn one side on
Old May 26, 2009 | 02:26 AM
setter11's Avatar
So far so good...
So far it has...
i know i did a proper install, but just to double check, i took
apart my bumper and disconnected everything, and the proceeded
to re-install it all over again, making sure to make a good connection
with all the plugs...
hope you get it to work...
everyone has told me it is just a loose connection...
Good Luck, if you start from scratch, send me an update...
Old May 26, 2009 | 09:04 AM
713_fit's Avatar
maybe i am being fooled, but thats WHY if you compare both the same temperature, I WILL REALIZE that it is a BIG difference.....and not just in colors...that why i said it be a BETTER comparison if it was the same color.....to show US people there is a BIG difference.....talk is cheap...show us with actions =)
im not trying to argue against you, i just really want to see a comparison. a true comparison with the same hid color.
alanchan
23
Jun 5, 2012 12:21 PM
ajksail
May 13, 2009 01:08 AM
ReeSpeed
18
Dec 30, 2008 11:30 PM
artieman
Nov 12, 2008 12:00 PM
yugisama
25
Aug 29, 2007 03:07 AM
