Sponsored by:
Sponsored by: CARiD
Poor Gas Mileage
Old Jul 13, 2009 | 03:37 PM
BSC_Tacks12's Avatar
Angry Poor Gas Mileage
I have a 2008 Honda Fit Sport edition.
I am currently getting 430KM per tank and have been averaging anywhere from 7.6L/110K (The best I have ever gotten) up to 10.8L/100K. This is WELL below what the car is rated for by www.fueleconomy.gov.
I have done no modifications, have stock tires with proper PSI on them and I don't drive like a lunatic.
Any thoughts on why the mileage is so bad? Are others experienceing the same issues Any thoughts on fixes?
Thanks!
Old Jul 13, 2009 | 04:34 PM
FELIXY69's Avatar
430km is alot already
most of us dont get 400km
and with mine being turbo..i dont get 300km
Old Jul 13, 2009 | 09:51 PM
seeremlive's Avatar
I average 34 Mpg (6.91 l/100K) over the 43,000 miles (70,000 K) in the last 18 months since I bought the car.
The major factor is how much motorway driving you do compared to city.
For example I drive 140 (225 K) miles each day going to and from work and I fill up every other day with about 8 gallons (30 L) . I do this at 70 - 80 MPH (110 - 125 Kph) on the freeway and 30 (45 kph) or so on the surface streets. It is about 98% freeway. Add to this a few miles here and there and I do 300 (480 K) miles every 2 days.
On the other hand
The other week I did 300 miles all in town and had to fill up 8 gallons (30 L) at 220 (354 K) miles rather than the 300 (480 K) that I normally do.
It all depends on the road mix of your driving, your heavy or light foot, shift points in a manual, and quite a few other factors. Looking at your reported (430 K) 267 miles. This says to me that you are driving in town more than 50%, or heavy footed or both.
All in all your not very far off of normal. A few slight adjustments and you would be right in the reported range.
Old Jul 13, 2009 | 11:28 PM
DOHCtor's Avatar
Check your Air Filter, exhaust system leakage (mess up your O² Sensor!), try an Injector Cleaner...
Marko!
Old Jul 14, 2009 | 01:42 PM
willmax11's Avatar
I just went and checked my odo and at 1/4 tank left I am at 440K.
Since April 2006 I have averaged 40 MPG. I keep detailed records on a spreadsheet every fill up.
LX auto. live out of town.
Old Jul 14, 2009 | 02:41 PM
Antpwny's Avatar
Has anyone checked to see if their brakes are sticking? Stuck brakes or brakes with too little clearance may be causing unnecessary drag.
Old Jul 14, 2009 | 07:04 PM
solbrothers's Avatar
auto or manual?
Old Nov 8, 2009 | 02:07 PM
minitruckersfit's Avatar
I average around 33/38 city/highway
When it gets cold here in ohio it goes down to about 29-31 city.
Old Feb 19, 2010 | 10:23 AM
larry11's Avatar
Correct tire pressure is very critical for good gas mileage. Check to make sure you have enough air in those tires..
Old Feb 19, 2010 | 11:14 AM
Black3sr's Avatar
I am happy with my 09 Auto. Most of my driving is hwy. I go to Brampton once a week at 120kph. I just filled up on Wed when the warning light came on. I was at 475 km. Fill up was 37 liters for $35. I am running on snows too.
Old Feb 19, 2010 | 11:40 AM
Vash's Avatar
your from canada man... unless your driving in like 90 degree weather... the coldness will always own your car in all different directions.
air is denser = car doesn't not move thru it as easily.
colder engine = longer engine warm up time
your most likely using more accessories such as the A/C compressor.
cold weather = winter blend fuel which also equals to crapy gas miles
Higher Altitude = crappy gas milages as well.
some of the things i have listed could be controversial, so feel free to state that any of those are miss leading or wrong.
Old Feb 19, 2010 | 04:50 PM
DOHCtor's Avatar
I wonder if my car can do 600 Hwy kms in sub zero temperatures.... The best i did last summer was 85X kms!! Amazing in summer, disapointing on winter!!
Marko!!
Blackbeard
Mar 9, 2015 10:44 AM
dgs
May 4, 2009 02:39 AM
Fitftw
Dec 24, 2007 02:07 PM
rstern
15
Aug 12, 2006 04:04 AM
MirrorWorks
Jun 17, 2006 01:34 PM
