Springs that won't lower the car
Old Aug 4, 2009 | 05:50 PM
CHERK's Avatar
Can anyone think of aftermarket springs that will not lower the height of the car. I have a 08 Fit Sport and I would like to stiffen up the ride but don't want to lower it. Any suggestions would be great. I've been looking around and the closest thing I can find is a coil over kit that can be limited to a .8 inch drop.
Old Aug 4, 2009 | 09:15 PM
Fitting's Avatar
Stock springs will not lower your fit
Swift springs give you the least drop being like an inch lower.
Some of the c/o can be set at stock height.
Old Sep 8, 2009 | 06:27 PM
DatFIT's Avatar
lol stock... your best bet is look for something that doesn't offer too much drop
Old Sep 8, 2009 | 07:25 PM
Daemione's Avatar
Many of them, if I'm not mistaken.
Old Sep 8, 2009 | 08:06 PM
redrumm's Avatar
might as well just keep oem or look for shocks
Old Sep 8, 2009 | 09:20 PM
willy65000's Avatar
I can't think of one good reason to raise the spring rate if you're not lowering your fit. The stock rates are plenty high. As Redrumm said, you're better off just upgrading the shocks or if you want to balance the car a little better you could just install a progress rear sway bar. That's what I did and it was a worth while upgrade for not much dough.
Old Sep 8, 2009 | 11:12 PM
Type 100's Avatar
TEIN High-Tech springs drop about 1" too...these are gold-painted instead of the green S.Tech springs which drop lower.
Old Sep 8, 2009 | 11:25 PM
Ms. Sheila :]'s Avatar
Last I checked, Tein didn't offer the H-Techs for the GDs. (I'm not sure sure about the GEs though.) I called tein before I lowered my car to ask if they were going to make it for the Fit because I know the H-tech's don't normally drop too much, but they said no. :/ I wanted a mild drop, and opted for the Tanabe GFs. It's too low, so no worries.
Swifts, however, offer the smallest drop.
Old Sep 20, 2009 | 07:02 AM
mrDFWmechanic's Avatar
RS-R's offer a drop of 1.1 all around, but you'd have to be in japan to get them as their not available to the us market yet.
Xtina
Feb 12, 2017 01:04 PM
danger69
22
Feb 13, 2011 01:28 AM
gee
Jun 26, 2010 07:39 PM
FIT_4_FUN
Dec 9, 2006 05:50 PM
Ah Ed
Canada Fit Forums & Clubs
May 30, 2006 10:32 PM
