Will i have rubbing problems? Enkei RPF1's
Old Aug 13, 2009 | 07:15 PM
Nighthawk_GD3's Avatar
Looking into ordering some Enkei RPF1's in 15x7.0 with a 41 offset. Will i have any problems being as im lowered with Skunk2 springs? If i wont have too many problems what would be the best sized tires?
Old Aug 13, 2009 | 07:37 PM
Texas Coyote's Avatar
I am using 195-55-15s on mine..... My car is at stock height and I had very slight rubbing on the front when cornering over a bumpy road surface but squeezing the plastic inner fender liner by hand fixed it.
Old Aug 13, 2009 | 07:41 PM
dewthedew's Avatar
on skunk2 springs? nah.
Old Aug 13, 2009 | 07:49 PM
How do you guys think the black RPF1's will look on a NHBP? Also what about using 205/50-15 size tires?
Old Aug 13, 2009 | 07:50 PM
Necos07's Avatar
205/50/15 will look good but I do think your gonna rub (not alot but some with bumps & hard turns). Stock size & offset is 55mm w/15x6 so your extending the wheel out a total of 27mm
Old Aug 13, 2009 | 07:53 PM
Will it be ok mounting 195/55/15 on a 15x7 wheel?
Old Aug 13, 2009 | 08:03 PM
Necos07's Avatar
yeah you will be fine
Old Aug 13, 2009 | 10:12 PM
mike410's Avatar
I have RPF1s 15x7 +35 dropped on skunk2 springs with the stock tires. I did the fender liner mod before I got the wheels on so I couldnt tell you what exactly that helped with. I rub on large dips/bumps and smaller ones when the wheel is turned. I just installed camber bolts tonight and I should rub even less than I did before. I am currently home at the moment so I dont know how it will do in areas that rubbing usually occured. You should be fine with the higher offset
Old Aug 14, 2009 | 03:47 AM
doctordoom's Avatar
Supervillain
if you use 205/50 tires you will rub the front clips on hard bumps/dips if you don't do any modifications to reduce rubbing. i don't know if you'd still rub with 195/55 tires.
Old Aug 14, 2009 | 04:20 AM
How come the 205/50's will rub and the 195's wont? On 205/50's the overall diameter is .37" smaller than 195/55's?
Old Aug 14, 2009 | 09:41 AM
MiniMiniVan's Avatar
The extra width of the tire is what is causing the rubbing. 10mm extra seems minute, but that's all it'll take.
Old Aug 14, 2009 | 10:00 AM
Fitting's Avatar
When I had my BC wheels in 42 offset w. 205/50/15 I rubbed front and back slightly. I was dropped on Tanabe GF which is a similar drop to the Skunks. Your best bet is to stick with 195/55 or 195/50.
Old Aug 14, 2009 | 11:49 AM
Thanks a lot for the input guys. Now i just gotta make sure those are the wheels i want. So im headed to the Modacar shop here in a few to look at a few other things and just because
Old Aug 14, 2009 | 03:07 PM
doctordoom's Avatar
Supervillain
no problem, good luck!
Old Aug 14, 2009 | 09:24 PM
JDMchris.com's Avatar
I run THIS
get the 205's.... they will rub... but it handles SOOOO much better.
Old Aug 14, 2009 | 09:40 PM
B1str0's Avatar
RubberBabyBuggyBumpers
when i was on my ssr's i didnt rub on 195 50's but now that im on 205 50's with my slipstreams i rub on hard dips and turns... mind you my fenders are rolled and fender liners tucked.. 205's feeeeeel so much better but look chunky..
Old Aug 14, 2009 | 11:00 PM
I dont really wanna roll my fenders. But what do you mean by fender liner's tucked?
Old Aug 14, 2009 | 11:30 PM
B1str0's Avatar
pulled out of its normal position and pulled above the lip on the inside of the fender
Old Aug 14, 2009 | 11:40 PM
With the 205's, will the rubbing be bad to the point of causing damage to the tire or fender? Or is it not enough to really worry about?
Old Aug 15, 2009 | 01:33 AM
I run THIS
no it wont be bad.
SBT
Jan 18, 2012 03:43 AM
MrPBuddy
May 31, 2011 05:02 PM
HB1320
Apr 29, 2009 01:49 PM
Spooling
Jan 29, 2009 12:50 AM
SHiFT
Oct 15, 2007 02:19 AM
