AirBag Compressor Noise
Old Sep 2, 2009 | 07:17 PM
FELIXY69's Avatar
Question for those who have bags
the compressor are super loud and i hate it,
what DO U do to keep the noise down ?
how many compressor u have ?
Which one u use ?
how often do they come on ?
and Please post a picture of your set up !
thank you !
here is mine 380C
Old Sep 3, 2009 | 03:51 AM
HONDAMATIC's Avatar
my gfs accord has one in the trunk, still kinda annoying, thats why i wanted to upgrade to duals so theyd fill faster.. if i were you id put a plywood trunk floor with some thicker insulation or something
Old Sep 3, 2009 | 05:44 AM
FELIXY69's Avatar
I was thinking plywood but that it help that much ???
Any pic of
ur set up ??
Old Sep 3, 2009 | 08:20 AM
stevet47's Avatar
You just need to keep it out of the interior. Either mount it under the floor, or in the engine compartment (although that would be a long hose run to the tanks.)
Old Sep 3, 2009 | 12:15 PM
5speedwonder's Avatar
create a box of 3/4" mdf plywood around it. inside I would insulate it with dynamat and egg cartons (this is how inexpensive soundproofing rooms is done). if you want to pretty it up you could carpet the box (this would even help dampen the sound further) or do something really cool like frosted plexiglass or a custom fiberglass coating over the box and paint it...or like steve said, just move it to the outside of the vehicle, this would be the quietest solution.
Old Sep 3, 2009 | 12:36 PM
stevet47's Avatar
The problem with putting it in a box is that you need an opening in the box for fresh air, otherwise 1) the compressor will have no air to compress, and 2) the compressor will overheat. The issue with that is, the sounds will now exit through the hole, so no matter how 'sound proof' your box is, it wont matter once you cut a big hole it in for air.
Just put the compressor under the car.
Old Sep 7, 2009 | 12:10 PM
awptickes's Avatar
Put the compressor under the car on the rear left side, right behind the bumper. There's tons of room over there. It's the spot that the muffler occupies on the rear right, just on the left.
Old Sep 7, 2009 | 11:10 PM
HONDAMATIC's Avatar
i was gonna tell him that but he got dual exhaust..
Old Sep 8, 2009 | 12:57 AM
solbrothers's Avatar
x3 ouch. lol
Old Sep 8, 2009 | 07:55 AM
FELIXY69's Avatar
if i put it out side of the car, wouldn't the snow, rain, dirt effect the performance ?
as for putting it inside, i can have remote air intake, but i would have no idea how to keep it cool,
jcuecker
66
Nov 27, 2018 04:52 AM
illissus
Feb 24, 2017 12:57 AM
angryhippie
Apr 21, 2016 10:30 PM
myblackhatch
Nov 12, 2011 12:45 AM
nexus4400
Jun 15, 2006 01:31 PM
