KraftWerks Fit High Boost and Intercooler Systems
Old Sep 24, 2009 | 04:39 PM
OJRKraftWerks's Avatar
Former Vendor
any chance of being able to get JUST the hondata? I have 310cc injectors already.
No. You must purchase the KraftWerks/Hondata reflash and injectors at the same time. This ensures the car will be ran with the proper injectors for the reflash.
-OJR
Old Sep 24, 2009 | 04:47 PM
Former Vendor
Originally Posted by rvall004
x2..for us that will be turbo charge hondata would be perfect while runnin 10 psi
The reflash is designed for use with the KraftWerks kit ONLY. It is not programmable.
-OJR
Old Sep 24, 2009 | 06:07 PM
aliencowboy's Avatar
Eldaino,
Really no difference in the sound, but there is a difference in the intake temps and the car is running great.
AC
Old Sep 24, 2009 | 08:22 PM
JDMchris.com's Avatar
I run THIS
Originally Posted by MNfit
I think I have to move the oil reservoir am I going to loss oil if have to relocated.
We relocated mine, and only a few drops came out. but the intercooler kit comes with the relocater and a longer line for the rotrex oil.
Old Sep 24, 2009 | 08:26 PM
I run THIS
here are some pics of mine
The highboost kit is awesome! As some of you know I was running highboost non intercooled. I can DEFINITELY feel a increase in power with the IC. It pulls better throughout the powerband. I can hear the supercharger blowing a little more now. big WHOOOOOOOOOOOOOOSH. The upgrade is definitely awesome! BUY NOW!
Old Sep 24, 2009 | 09:45 PM
keepitpg's Avatar
i love college
Originally Posted by eldaino
actually i think if you bolted it on it WOULD work, but how it would run/hold up is a different story.
mid boost....mid boost....say it with me....
The intercooler? it fits the AT, its the Highboost kit that doesn't work with the AT
i meant the kit wouldnt work.. right..
it would work but would be shitty without a good tune.
Old Sep 24, 2009 | 10:50 PM
Koi's Avatar
Koi
I want this. I need this. I... don't have money for it right now.
Santa Ana season = need I/C
Old Sep 24, 2009 | 11:20 PM
Wytt's Avatar
Intercooler Kit on an AT: Yes, just look at AlienCowboy.
High Boost Kit on an AT: No.
Old Sep 24, 2009 | 11:24 PM
Koi's Avatar
Koi
Do you have to rotate the battery, or is it supposed to fit w/o doing so?
Old Sep 24, 2009 | 11:29 PM
dewthedew's Avatar
looks like it would fit without moving the battery at all
Old Sep 25, 2009 | 12:30 AM
I run THIS
All you have to do is remove the little casing/tray thing that is around the battery... that allows you to move the battery over about 1/2 inch for clearance.
Old Sep 25, 2009 | 11:07 AM
  #32
Wave's Avatar
Still hasn't been addressed:
Will strut tower bars get in the way of the IC kit?
Old Sep 25, 2009 | 01:27 PM
  #33
Wytt's Avatar
It doesn't look like it. Just from looking at it, if the bar goes up high (like the Mugen or Spoon) it gets in the way of the scoop. If the bar goes low it looks like it would get in the way of intake. I believe AlienCowboy said he couldn't fit his, but I don't know what brand his is. I have a Mugen, but never got around to installing it, but I'll check when I get my car back (but as of right now it looks like that will be going up for sale soon )
Old Sep 25, 2009 | 04:07 PM
  #34
MNfit's Avatar
I think this pic says it all right here. With the intake and hose it looks like there is no way for a strut bar to work.
Old Sep 25, 2009 | 04:19 PM
  #35
I had the Aspec tower bar, and I had to remove it.
Old Sep 26, 2009 | 12:14 AM
  #36
Stevens24's Avatar
Is the ECU pretuned? and if so how would that work at altitude(CO 5800 ft)? Ant ideas?
Old Sep 26, 2009 | 12:24 AM
  #37
Wytt's Avatar
They do most of the tuning here in SoCal, but the Jacksons check there tunes around different climates (of course, being in SoCal, they get majority of different conditions nearby). In fact, they do go up to Colorado and test their tunes and make any adjustments.
Old Sep 27, 2009 | 05:15 PM
  #38
Former Vendor
Stevens,
Your ECU is calibrated by Hondata. It is not adjustable. The calibration is designed with the same principles the factories take for performance, drivability, and safety.
Our durability testing is tough. We do not simply test in SoCal and call it good. We drive multiple long distance trips in the winter and summer to ensure calibrations are correct. We also drive up in the Rocky Mountains (Colorado) for extremely high altitude testing (10,000ft passes and such) in winter and summer. In fact, we recently did an August test across the Nevada/Utah desert to CO to test another new kit. It was well over 110°F across the desert, pulling long grades.
The ECU is designed to calibrate in all of these environments. It is a factory Honda ECU after all, so it was originally designed to calibrate accordingly.
-OJR
Old Sep 28, 2009 | 11:48 AM
  #39
Stevens24's Avatar
Originally Posted by OJRKraftWerks
Stevens,
-OJR
Thank you, I figured it was that way but thought i should ask to be sure. So basically it will adjust to conditions just like the Factory ECU. Cool, Thank you for the response.
Old Sep 28, 2009 | 11:51 AM
  #40
dewthedew's Avatar
Just wondering what kind of boost is made at 7100rpm vs 6500?
