Ground control coilover sleeves!!!!
Old Sep 27, 2009 | 09:23 PM
wait4thefit's Avatar
i just looked to see if they made these for the fit and they do!!
my friend had them on his db8 typeR and it had an amazing ride.
429.99$$$
Old Sep 27, 2009 | 09:44 PM
im the fit's Avatar
Awesome find, do they fit over oem shocks? and what is the spring rate on those
Old Sep 27, 2009 | 09:51 PM
yea they go on just like lowering springs. idk the spring rate on them cause it doesnt say
Old Sep 28, 2009 | 10:01 AM
HB1320's Avatar
what site?
Old Sep 28, 2009 | 05:36 PM
well weaksauceparts.com has them!
Old Sep 28, 2009 | 05:59 PM
GD3_Wagoon's Avatar
Dela is running ground control sleeves on his GE. i helped with the first install and it is a very nicely constructed set-up. if you contact ground control directly, you can order the height of the drop and spring rates at whatever specs you'd like.
Old Sep 28, 2009 | 08:31 PM
dela's Avatar
hello!
dela would be me...
the website is www.ground-control.com
i'm on stock shocks as of now but plan to get konis when available
from what i can remember...
the standard specs are
front 6" springs/2.5" diameter/ 375 lbs per inch
rear 10" springs/2.5" diameter/ 150 lbs per inch
my specs are slightly different...
but give them a call.. they are awesome to talk to, tell them what you want to do with the car and they'll give you suggestions... and if you're set on what #s you want they probably will gladly give it to you...
Old Sep 28, 2009 | 11:25 PM
is you car lowered all they way in that picture?
Old Sep 28, 2009 | 11:34 PM
accordguyintake's Avatar
this would prolly be tied #2 with buddy club coilovers for what i want to do with my suspension. #1 being enduratech
Old Sep 29, 2009 | 04:06 AM
dela's Avatar
can go down a bit lower but i dont want it slammed... n i have 15" wheels with 50 sidewall tires.. so the gap is bigger then if you had stock size tires... and theres not a lot of available sporty tires in 15" with a 65 sidewall
but if you want to SLAM your car... i wouldnt recommend GCs... D2s do a good job of slamming...
although you might get better adjustability from different full coilovers, the GC/koni combo is a popular set up for many cars in terms of handling... (which is the route i plan on going, eventually)
Old Sep 29, 2009 | 04:30 AM
Type 100's Avatar
Thanks for these specs.
Converted to metric units, the spring rates would work around to:
Front = 6.69 kg(F)/mm
Rear = 2.68 kg(F)/mm
On paper they're kinda stiff up front for a GE I think. How are they handling so far?
Old Sep 29, 2009 | 01:54 PM
i want to lower my car alot and still have the good handling that GC has
Old Sep 29, 2009 | 02:07 PM
dela's Avatar
well as of now.. on stock shocks.. it feels WAY oversprung all around... but i took it out around malibu mountains with my mr2 buddies and it handled great, kept up with some of them...
but yeah... im dying for koni to release something already.. lol
call them... they can help... but if you want to go lower, you can either lower the spring rates and/or reduce the spring length...
if you go to the GC website you can check out all the available springs, basically mix n match... 2.5" diameter springs and GC 64 mm springs are what your looking for
*edit* just a suggestion...
im sure you can go a lot lower with these springs...
front
GC150.64.53 (6/2.5"/300 lbs)
rear
Eibach Springs, 0800.250.0150
(my rears are actually 8" springs/2.5" diameter/ 175lbs per inch)
Old Sep 29, 2009 | 02:33 PM
dela's Avatar
example
GE fit sport
2520 lbs curb weight
62/38 weight distribution
1562lbs front/957lbs rear
781lbs each front side
478lbs each rear side
standard specs
781lbs(1in/375lbs)= drops 2.08in
478lbs(1in/150lbs)= drops 3.19in (in a 10" spring)
suggested specs
781lbs(1in/300lbs)= drops 2.60in
478lbs(1in/150lbs)= drops 3.19in (but in a 8" spring, it goes 0.5" lower then mine)
so potentially goes ~0.5" lower all around compared to my GCs...
Old Sep 30, 2009 | 01:20 PM
Special's Avatar
exactly why i sucked it up and ordered some skunks... I really wanted GCs for their ease of adjustbility, but I didnt wanna run oem shocks
Old Aug 27, 2015 | 01:12 AM
space egg's Avatar
6 years later... this thread is still helping folk!
thanks
Old Oct 6, 2015 | 01:17 AM
Regdog77's Avatar
Anybody else have gc, specifically with Koni orange?
Old Oct 6, 2015 | 02:07 AM
space egg's Avatar
TofuShop
3rd Generation GK Specific Suspension & Brakes Sub-Forum
May 6, 2016 05:20 PM
tonkatsu
Dec 20, 2013 06:08 AM
cojaro
Feb 14, 2010 12:31 PM
Mines13
Mar 6, 2007 09:13 PM
Jo2
Nov 6, 2006 03:23 PM
