Clear plastic over gauge cluster scratches
Old Oct 30, 2009 | 02:18 PM
flyellow's Avatar
Originally Posted by Rod2Rice
Off top of my head, the first layer around the gauge cluster is simply clipped on. Put the steering wheel in the lowest position, then start to pull gently at the bottom to unclip, then work around the sides and up to the top. The bottom and sides unclip fairly easily, the top feels like its going to break, but it did not and eventually popped right off. It uses some of the same clips that the radio is installed with, so if you have swapped radios you know how tight those clips are. Once that is out, you can see the screws that hold the lower part of the hood over the gauges, take those out, I believe there were 4, then take that lower part of the hood off. Once that is out, you will see the 5 screws that hold the upper part of the hood on. Remove those and then the upper part of the hood. Then you will see the cluster and the screws that hold it on. I think there were 2. Then unplug the 3 harnesses on top of the cluster, once those are out, manuever the cluster to one side, then lift it up and out from the other side. That last part you will see what I mean that needs to be done when you get to this step. Once its out the plastic cover is just held on with a few tabs. Hardest part was removing the part in the first step, the top clips are a pain in the rear!
any way you can provide pics....!!! I am verbally challenged!
Old Nov 6, 2009 | 03:04 PM
Rod2Rice's Avatar
Sorry I no longer have the car so I can't.
Old Nov 19, 2009 | 01:24 PM
cflhonda's Avatar
Former Vendor
If you are looking for a replacement we have them in stock at $15.53.
Thanks,
Dan@CFLHonda
Old Apr 22, 2011 | 10:30 AM
JoceFit09flo.hio's Avatar
I know this is an old post BUT...
I just bought an '09 Honda Fit and the plastic is OWNED. I dont know if the person who had it prior to me just kept trying and trying to clean it incorrectly and made a game out of it, or was just too careless to noticed. Anyway, its ruined. Does anyone know the part # or what i can "google" search for inorder to find it.... I know the BF and i could probably get it installed, or take it Honda....
PLEASE HELP!!!!
BlueRaspberryFit
May 28, 2014 10:58 PM
gkitf16
May 8, 2014 10:11 PM
gkitf16
May 7, 2014 07:03 PM
kenpoist
Oct 6, 2010 02:42 PM
NY Fitted
Feb 4, 2007 11:37 AM
